anfa
Hi, this is the first time I've posted something I've made.
I made a Sci-Fi hand grenade.
It was made from a screwdriver set thingie similar to this one but not the same(I should have taken a photo of it before I started).
The lever thingie was cut from a shampoo bottle.
I've updated the pin from a hair pin to a proper split pin. lol
When you pull the pin and release the lever, blue LEDs flash(well, one LED in the centre with fibre optic tubing going to the LED housings) and it vibrates(I installed a small motor with a bit of plastic stuck on the axle thingie). I'll make a video when I'm sober.
I also filled the base with air-dry clay to give it a bit weight so it feels good to hold.
The "Kriger Corporation" thing is because I wanted to create a fictitious evil corporation that makes this type of gear. I just stuck a load of words in Google Translate until I found a word that sounded right. Kriger is Danish for warrior and the logo is a simplified Viking shield.
