epochcraig
Hi there all....ok here is my first prop/mask made from start to finish...it is the michelle pfeiffer mask i have incoporated the chin strap into the mask just makes it easier than trying to make this after looks good when being worn all in one..
i made the the original from a sculpt and then casted a master mould out of hurculite 2 and then rotate/slush casted the late with pigment after here are the pics bellow ........thanks for looking
here is the first pics of the sclupt
here is where i started putting the ears on the sculpt
i started to do the smoothing out of the mask and adding the stitching
i missed tacking a pic of applying the plaster for the mould but here is the pics as i opened the mould after it set
as you can see when opening it destroyed the original sculpt so no going back on detail now lol
you can see where the clay is stuck in the stitching which i cleaned out with a tooth pic
here is the first pull out of the cast all it needs is the eyes and mouth area cutting out and trimming i was going to paint it but opted out and used black latex pigment which you will see bellow
ok here is the finished mask in black and stitching all painted up not to bad lol
