Egon Spengler
Okay. I have a project I'm trying to fix up that I'd rather not reveal at this time. I need to securely attach two pieces together. There is a large gap around the main object that the side pieces need to connect to. I'd like to fill these gaps in with Bondo and also smooth out some of the surface areas. Is there a certain type of glue or wire or something I can use combined with Bondo to make everything stronger, more stable and also fill the gaps in with as well without worrying about it all cracking apart?
I've never used Bondo before either... but have a can of it i've been wanting to use for sometime now. I'm just nervous about it.
