Benthic Two Tubes - Build journal
Re: Benthis Two Tubes - Build journal
Cant anyone see the pictures or is it just me where its saying I need to upgrade my account for 3rd part hosting? :confused
Photo-bucket strikes back!
Lots of members seem to have suffered this unfortunately...
chech the Photobucket related thread in the OT forum
I just saw this thread and I am very interested in seeing the pictures Silverstalker if you can get them to work. Maybe try a different host site? Seems like photobucket is unusable now.
It's not the first time they've changed bandwidth policies with no warning. I moved on from PB years ago for this very reason.
Silverstalker, I'm really keen to see your Edrio build. Do you have a blog or site where this is also posted?
Hi Silverstalker, I've seen your finished product and it looks great, but I'm keen to see your whole build process (as are a lot of us it seems).
Could you possibly upload the images to another site such as flickr and share the album?
+1........
I have moved most of the pictures over to my new Flickr account, sadly a lot have been lost a long the way... I have deleted the first post I made as it was full of dead links and copies of pictures it was a real mess!!
I am going to up load again with what pictures I have left... I can add details to the build as I go and answer as many questions as I can...
More to follow soon.
The head... basic fitting using card
20170510_105043 by Silver Stalker, on Flickr
20170512_104820 by Silver Stalker, on Flickr
20170513_140409 by Silver Stalker, on Flickr
20170514_134627 by Silver Stalker, on Flickr
Home brew silicone mold,
bucket of Ice cold water, 100% clear ''construction'' silicone, washing up liquid to act as a catalyser it sets the silicone in about an hour..
20170613_182655 by Silver Stalker, on Flickr
20170614_214343 by Silver Stalker, on Flickr
Pollycraft SG2000 I used for the cast
20170615_090840 by Silver Stalker, on Flickr
20170613_190814 by Silver Stalker, on Flickr
for the neck seal I used cellophane to wrap round my neck and side of my head, covered that in duct tape, pulled it off and cut into fabric templates I can used to transfer to suede fabric
20170624_135224 by Silver Stalker, on Flickr
I used a zipper on the back that will be hidden by the rear head plate and neck scarf
20170625_073752 by Silver Stalker, on Flickr
rear back plate thingy, just a collection of parts thrown together
20170622_153056 by Silver Stalker, on Flickr
held on with magnets on the inside of the neck seal.
The leather coat was one I found on e-bay for £40 genuine leather and broke my heart to cut it all up!
Screenshot_20170613-203432 by Silver Stalker, on Flickr
Sadly I don's have pictures as I modded it due to Photobucket not letting me have them back????? I also have no original pictures left
but what I can tell you is the screen used one looks kind of blue(ish)? I found that when you used a foam backed 120 grit bit of sand paper it removes the dye and roughs up the leather to the point it goes fluffy and ......blue! (ish) so I did that all over and it took all day!!!
I also removed all the buttons, button holes, lapels and collar, I have to make a new hem line after cutting it all up, this I had to do on a fabric sewing machine as I don't have a sewing machine for leather, to avoid damage to the machine I hand cracked the whole lot..... this to a life time but worth the extra effort..
The two tube part of it was tricky.... plastic pipe was to big and would not sit right so I didnt even bother trying with it, what I did note is rope hands nicely? so I will be using that a s a 'core'
but first I cut up 80 small sections of pipe from an old shower rail with a little pipe cutter..
20170609_152925 by Silver Stalker, on Flickr
covered the rope in insulation tape (crude yes) but given the close proximity of each pipe section the tape will never be that visible and after its been weathered and matt clear coated you would never know..
20170609_144654 by Silver Stalker, on Flickr
for the connecting ends I simply increased the size of each pipe section and made it thicker with the tape..
20170616_134138 by Silver Stalker, on Flickr
20170616_112020 by Silver Stalker, on Flickr
I bonded the whole lot together and used a simple nut and bolt to hold the tubes in place that can be removed for storage... the end result is two pipes that bend nicely and also hang nicely..
Can you guess what it is yet!!
20170530_113906 by Silver Stalker, on Flickr
moving on...
Boots were easy...
a pair of high top chelsea boots with the pull tabs moved to the sides
20170704_171709 by Silver Stalker, on Flickr
20170704_175439 by Silver Stalker, on Flickr
The trousers were another difficult one, they seem quite puffy on screen not like combats or khaki type trousers...
So I used a pair of skiers trousers as they are padded and long, this will have nice over all look, I simply added the knee pad area and painted the whole lot, sealed and weathered
the only pic I have is of the knee pad....
thanks again Photobucket..
20170605_154105 by Silver Stalker, on Flickr
The hands/gloves were also simple, a pair of sure grip type cloves with PVC pip cut up into half's and chipped away to look crab/bone like and bonded
20170529_141707 by Silver Stalker, on Flickr
20170529_135749 by Silver Stalker, on Flickr
The tunic-
again.... PhotoBucket have screwed me... I didnt use parachute silk as that seems to be the source material, instead I used a silk variant mixed with polyester, its shiny and it will take weathering a lot better..
20170609_193156 by Silver Stalker, on Flickr
The Blaster-
I managed to scale up a picture of the blaster after a long slog round the internet..
20170515_150419 by Silver Stalker, on Flickr
20170516_144941 by Silver Stalker, on Flickr
20170518_090958 by Silver Stalker, on Flickr
20170518_134944 by Silver Stalker, on Flickr
I used the connecting part of a pool cue to attatch to the barrel, this way I can take it apart and trabsport it, its a long thing is this!
20170518_143053 by Silver Stalker, on Flickr
Scope, to be filled and fitted
20170519_152322 by Silver Stalker, on Flickr
20170527_155702 by Silver Stalker, on Flickr
20170527_155658 by Silver Stalker, on Flickr
The Belt-
Sadly more pictures missing....
I used PVC leather, it ages easy, can run it through a machine and inexpensive.
20170621_200632 by Silver Stalker, on Flickr
Not a lot to see on that really, I wish PhotoBucket would let me have all my pictures back,,,, it's getting anoying!!!!!!
Back Pack-
No pictures....... can you guess why....
Gas Grenade-
made from, card pipe, ring from a folder book, bit of cable trunking... anything really
20170703_144841 by Silver Stalker, on Flickr
20170703_150359 by Silver Stalker, on Flickr
20170703_192211 by Silver Stalker, on Flickr
Guys and Gals there are so many pictures missing, the details I put into the pictures told a much better story, I can only offer advise as to my journy on this, it's not 100% on point there are things that need to be improved but I can do this along the way. So far its worked out great for me and I love it so far...
I need to add the lenses into the eyes as they need to be silver but I will keep going with the little extra parts over the coming weeks, so here it is as it stands now....
Lots to do, lots to improve but its almost there..
20170704_223944 by Silver Stalker, on Flickr
20170704_223727 by Silver Stalker, on Flickr
received_1589671441065568 by Silver Stalker, on Flickr
20170704_223912 by Silver Stalker, on Flickr
20170704_223809 by Silver Stalker, on Flickr
The pictures are little over exposed I guess... I will have so better pics end of the month, I will be at London Film and Comic Con in a few weeks at the 'Joker Squad Star Wars Group' stand...
I have made a few more mods to it now, its slowly looking a lot better, I will get more progress pictures up soon....ones that are not over exposed :lol
Wow! Master class in scratchbuilding, with a brilliant and inspiring tutorial to boot! :thumbsup
thank you kindly, I only wish I had more of the pictures. I will never know how or why the vanished from Photobucket..
I went to London Film and Comic Con last weekend, I trooped about 2-3 hours and I was done! this is the hottest thing ever ha... I will upload some pictures of the event at some point .
