when making the helmet, put a plastic sheet at the front of the mask that u can clearly see out of when u put it on, cover the plastic sheet with painters tape and spray the whole thing black then take off the tape and use mesh to paint a red carbon fiber design over the entire thing, or instead of a sheet, u could do sunglass lenses or a motorcycle visor that way its tinted darker. Once u have the red painted, you'll be able to see through the front but not as clearly because theres a bunch of dots from the carbon fiber paint job, but they should be small enough that it shouldn't make a difference. Good luck!
