Rob1970
Mhm... never claimed I was sane. I am going to attempt a Sherman DD scratchbuild based on the Airfix kit. Nice and cheap. Only have to figure out how to make the screens, drives and assorted doo-dads. How hard can it be?
Box!
Parts!
Reference stuff!
Well, here it is; my first venture into vehicles in like... vorever! Uhm... I mean forever. This bit of scratchbuilding has been on my list ever since a D-Day GB turned up on the planning for another forum, so I'm pretty stoked to get on with it. Picking out pieces from the pile of pristene parts to put together was a bit of a put-off.... sooo many to chose from!
First I bodges together a bunch of bogeys...
Hilarity ensued when three halves made a whole hull...
My god.... I am not going to do this the whole build...
The rear-end of the hull has a couple of bumps which are supposed to look like actual drive-bits (hey, I'm not that indoctrinated by the Dark Side I know what all the bits are called... yet...) but I need to replace them with something that looks like the DD-gubbins. So off they go!
Keeping tabs on the hull. ya never know... it might wander off...
Oversized skirts are just not a good look on a Sherman. Good thing it's only a template from some thin styrene stock I'm tinkering with.
Trying to get the shape and size right with the help of pictures from the interwebs, reference material and ye olde Eyeball Mk.I
Getting there...
A good thing with using templates; you only need to get one side right, and just flip it over when you transfer it. In this case to 1mm styrene stock.
Template transfered thanks to tape, tenacity and a scribing needle... (so close... soooo close...)
It looks the business... just need to add some curves to the front.
Just a little dip... very subtle, innit?
The front needed a little more bending, and ofcourse broke... so I made an insert sligthly larger then the bit that broke, giving me the material to make the bends. Fixed in place with CA-glue, because I didn't trust the Tamiya Extra Thin with all the stress on the plastic.
Made a hole for the exhaust system. Some DD tanks actually had large funnels on top of those to vent the gasses out about the screen. I think I will just settle for the normal exhaust.
Time to close that hole in the front (bow? It is a boat of sorts, right?). A lot of tinkering with scraps of styrene. One side first...
Both sides done and trimmed.
Front done, a touch of putty on the seam on the inside. It will need a little careful sanding...
...as does the outside...
A little sanding did wonders for the bow. Inside...
...and out. Just needs a little more thin filler and it should be fine.
Next up; the exhaust trunk. Made from a bit of Evergreen tubing split in half and glued to a strip of 1mm styrene stock.
Cut to the size I need, and with two more bits of stock glued on to make the sides.
Excess fettled and sanded off on on one side...
...and on the other side...
Glued in place...
Sides cleaned up and a bit of rod added as a hefty weld.
And we have a trunk. Now it needs another bit of trunking/guard.
While looking for reference pics I actually found a site with a lot of CGI-models of all kinds of stuff. Among other things a DD Sherman! Score! Very nice clear pics when you are doing scratchbuilding.
Scratchbuilding sponsored by a well-known fast-food company. You get a nice bit of thin styrene stock, and a bonus ice-cream!
Origami for beginners... 6mm strip, folded and kept in shape with a little strip glued on the inside.
Cut to size, with a narrow strip added to imitate the folded edge they originally did to stiffen the sheetmetal.
And fixed in place. Just needs a little clean-up once the glue has set.
And on we go... Starting with taking the details off the front. The headlights need to be raised on stalks, to reach over the DD screens. And I wanted to do new hoisting rings as well.
Did the same to the rear. Also took off the tools, because the molding was quite soft. Cleaned up the splash-guard(?) and I made a start with new details. The air vents were blanked off with a plate welded on. New hoist rings made with copper wire.
Rings and closed vents on the back...
...and on the front we got rings too. And holes for the new lights.
New lights made from small discs of styrene...
… a bit of 0.6mm styrene rod. The little drop you see is CA-glue, to from the domed back-end of the light.
A staple turns into a little guardrail...
I had to repeat the drop of CA on the back of the light a few times to get the dome I wanted, and gave them a lick of paint just to check them.
Lights and guardrails in place...
Verrrry happy with the results...
A tiny piece of styrene rod and some lead ribbon on it's way to become one of the rear lights.
Another bit of lead over the top, and it looks kinda right... altho this might be redone... not as happy as I could be...
It looks kinda right... But I might redo them anyway...
Did some work on the turret, adding hoisting eyes, the ammo loading hatch and the little platform for the “captain” to stand on. The frame for hatch needs more sanding and putty, but it defeated me for now...
Still pondering if I should add the mount for the big .50 and the gun itself (I have one lurking around in the spares box.). Some DD tanks had it, others didn't.
Been tinkering with the tiller system, making little brackets. The “captain” could use it to steer the screws, although most of the steering was done by making one screw go faster then the other.
Tiller handle and rod...
It should look like this, but it's not going on until I've done the underside and the drives of the tank.
More sooon!
Rob
Box!
Parts!
Reference stuff!
Getting there...
Glued in place...
More sooon!
Rob
