Will Vale
Member
Hi folks,
I've been messing around assembling some GW stuff since I finished the Viper but haven't really got my teeth into anything. And then I spotted an interesting part in a kit, turned it upside down, and went and got my big Chris Foss book out...
I've wanted to build some '70s or '80s sci-fi for a while and this should scratch that itch. The part I found (can you spot what it is?) looks great when inverted as an under-slung bridge. I did a couple of designs around this - one as a tug or recovery vehicle, with a hexagonal body and arms sticking out the front, and one as a more conventional starship with a pyramidal body.
I taught myself to use Sketchup (very basically) at the weekend and worked out the dimensions, so last night I was able to cut some parts and tape them up:
The core is a plate of 2mm styrene, and the rest is 1mm. I laid it out with a ruler and dividers, taking the dimensions from the Sketchup model, and cut the parts out with a Tamiya scriber. Amazingly, it fits quite well despite the model not accounting for thickness. I did have to build a second version of the rear plate though since my first attempt had the angles very slightly out.
The idea is to cover it in plating and nurnies (flat ones on the surface, dense ones in the notch around the bridge) and paint it with bold stripes! Hopefully that will stop it from looking too much like a Star Destroyer.
First of all though, I need to cut out various access hatches and internal access holes, then make the bulkheads to fix the angled plates to the core.
Cheers,
Will
Cheers,
Will
