Well, Halloween has come and is now long gone, and here I am finally getting here to mention it.
Ladies and Gents, Gambit:
My biggest regret is not getting more pictures taken...
Ok, so what we have here is a randomly-found brown rain-trench with purple silk interior (what?.). This had to be modified because it was extra-large and I am not. I'm like, MediuLarge, so the shoulder straps were tightened to bring up the arms, and then stapled in place.
The Leg guards are plexiglass with Krylon chrome spraypaint. I used a thin piece of plastic (think saran wrap) to wrap around my leg. This was used to size it, because once my leg was wrapped I cut up along the back to make a 2-d pattern of my lower leg. This was dremmeled out of the plexiglass, then I had the great joy of sitting in a chair for 3 hours, heating up the plexi over the stove and wrapping it around my legs.
That hurt, and I now hate plastic.
Most of this is pretty straight forward, but it's the Cowl that is my pride and joy. So much work went into it.
No, I'm not drunk, I'm distracted...
This cowl is composed of black cotton stretch weave, very thin black vinyl, bristol board, Liqui-Stitch latex fabic adhesive (which smells like cat pee while drying. I'm glad that faded fast.), Velcro Glue, and most importantly, staples.
I first wrapped my head in green painters tape, then carefully drew onto it the shape i needed. This was cut off my head, and then the parts were trimmed and cut from vinyl to form the following panels:
I worked out the stretch ratio for the cotton weave, measured the diameter of my neck, and made a tube with a slightly smaller diameter. The 3:1 stretch ratio made it so it could still fit over my head.
Then, with the patience of a madman, I sat still for 3 and a half hours with a tube of black material over my face and neck as my housemate carefully glued every panel into place using the Liquistitch.
The holes were then cut out, and identical copies of the panels were cut out of bristol board and glued to the inside of the cowl to stop the panels from curling up under the pull of the cotton.
Staples were used on the bit just above my adams apple to pull the cheeks in tight, and there it was:
I'm going to have lunch now, and then I'll talk about the chest-plate (which took forever), the Gloves and the gorget (neck collar thing).
Later,
Myster Mistery
Later,
Myster Mistery
