Shirt (concluded)
Back to the Shirt...
I finished up the back atomic shapes, and tried my best to fix up the first one I did with some success.
Then I started on the pink stripes. At first I thought sewing them wouldn't be that tough, but then once I started I realized it takes a lot longer than I was expecting. You have to make the sew lines really dense, so it takes a while. Since I knew I would run out of time, I ended up only doing the front this way, and using pink puffy paint for the back.
Then I started with silver lines and purple dots with puffy paint. As you can see, the silver goes on gray-ish but dries really shiny. This is where it was really starting to come together.
Next I attached the sleeves, which was no easy task. I don't know how shirt makers normally attach sleeves, but this part got a little sloppy. I ended up sewing it on any way I could, and then hand stitching the parts that I couldn't reach with the machine.
The atomic symbols on the sleeve were too small to use the soutache cord, so I went straight to the puffy paint. While doing this, I was reminded why I hate puffy paint. It's so hard to control and get right. But I think it turned out ok after much aggravation.
Here's how it all looks finished:
Next I'll show some photos of me in costume from work.
