qcfoundry
i've tried to snoop around other boards for a fix to this and nobody seems to have the correct answer. a lot of "home-brew" answers (e.g. print to .pdf, when using WINDOW to print-make a smaller window) -- but all have failed so far. as for when i have tried the .pdf backdoor fix...it only worsens the discrepancy.
i really want to apologize to everybody for this. as i said, i assumed the information was working properly and i didn't check along the way.
to persons that have the drawing in .dxf or .dwg, the file is still good. as allan and i've noted, the bugger happens when printing or exporting.
i have another project that this problem is affecting, so i'm going to continue to try to figure the solution. i've tried printing out at a large scale, measuring the discrepancy, then make a drawing that has been "artifically" enlarged for printing reasons only, but this is kinda like treating the symptom, and not the problem -- not good enough for me.
again, sorry...and i'll keep ya posted if i figure this out.
