For the Martian Pistol Tac light, here is a knock off on sale with a 15% off coupon for $33 on AmazonRe: The Expanse: Prop Weapons
OK, the new tac-light is the LaserTac subcompact combo green laser & flashlight. Retail is $130 US.
-MJ
Would you be up for sharing the template?After binge watching all 6 seasons for the first time I knew there was one ubiquitous prop I really wanted to make.
I just finished my Belter Hand Terminal.
It has the same "slap band" led circuit inside with the on and flash mode. I had to de-solder the blue LED and replace it with a yellow SMT one which was a really fiddly job but I got there in the end.
I may print out a graphic for the display but for I'm happy that this is a set accurate prop.
I am currently re-watching the show, and got in the mood to try my hands at a paper prop. It's the code word sheet Alex pulls from the Roci's operations locker.View attachment 1613795
Here's what I have cobbled together so far. I am still fiddling around with the spacing of the respective text blocks.
As far as the fonts go, I used one called "Federation" for the actual code words, and I think it is a near enough match.
However, I am pretty certain that the "COMMAND STAFF ONLY" line has the wrong font. The one I used is "Flexi-IBM-VGA-False", and it is quite close - except for the "D".
Can anyone identify the font they actually used?
Thank you for the Aldrich font tip!Can check when I get back if helpful? I do recall the other font I used is Aldrich, as I used it on many Expanse props.
Here's the one I did a couple of years ago, I don't know if the font is correct, but it looks closer than yours. I can check back on my files, but I just arrived for two week's holiday in Portugal, and the files are on an external drive at home. Can check when I get back if helpful? I do recall the other font I used is Aldrich, as I used it on many Expanse props.
Thank you, that would be very helpful. Enjoy the stay in Portugal!I should have some blu ray captures which may be a bit clearer, will check when I get back.
Absolutely!And donkey balls lol.
Ah, thanks, Noeland, I probably needed that. I was half-way back to those font websites again...Really nice work. It looks great guys. Bear in mind that some times the graphics dept on show like this will take an existing font, set the type, then convert it to outlines and modify the font here and there. They also create their own fonts. So you may not find an exact match.
Where an I buy these cool Expanse props?If you have any sets of parts for the star helix pistol I would be interested in at least one set, pending cost ,if you have any left, and possibly the martian pistol too?
