<div class='quotetop'>QUOTE(clutch @ May 2 2006, 02:08 AM) [snapback]1236685[/snapback]</div>
Since the arms are hollow, how exactly did you get the wires to stay at the elbows? Any pics of how you did the feet? I cut mine mid-foot and I can BARELY get the boots on him, much less get them off again.
[/b]
I cut about 3" out of each arm where the mannequin's elbows were.... I used wire coathangers for the flexible elbows... didn't unravel them... just pulled them out into a long rectangle and jammed one end up the hollow biceps, and the other end down the hollow forearms, so basically there's a double length holding each arm together. I then laid some glassfibre matt (saturated with glassfibre resin) between the inside wall of the arms and the wire, and also over the top of the wire, so it sealed it tight against the wall of the arms. Then when it had set I filled the elbow 'void' with bubble wrap and foam, finished off with some duct-tape to hold it all together and give it a natural shape.
Unfortunately I didn't take any pics at this stage, as I was getting 'near the end' and was too impatiennt to take time out for photographs.
As for the feet... I noticed early on that the mannequin didn't lean foward on it's toes when standing on the base (with the steel support through the heel of it's right foot) so I decided to amputate the toes altogether.
So the feet are really just 3/4 feet which I then made 2-part with the blocks of wood inside and the screws etc. etc. Hasn't affected it's stability at all, and makes it less stressfull putting on, and taking off the boots.
Again I haven't any pics of this stage, but hopefully you understand what I mean
I've had a few PM's asking if the rear of the base has lighted panels as well, and asking for pics of the rear of the costume. Yes, the base has 6 lighted panels... one on each side, with the rear 3 sides being a mirror image of the front 3 (although the back centre panel has a small hole for the electrical cable)
Unfortunately the mannequin and costume is currently at my friend's office / showroom, and the nature of his businesss means I can't take pics... Sorry :unsure
Cheers,
John
