HEY GUYS!
So my -Tssy2005- Sherlock Custom coat came in.
NO PICTURES. So im Very sorry. Also, keep in mind I purchased the coat with the thought in mind; I like sherlock but I dont love sherlock. So how accurate it is isnt what im looking at in my review of this coat. Just the coat itself; and my opinions on the coat.
RUNDOWN:
The material is a decent quality wool. Refer to user anthonygrey on page 24 for a few good shots of his coat.
But like I said; the material is decent quality wool. More than likely it's a wool blend with a minimum of 35% - 60% wool and Polyester to fill in the rest. Overall the coat is about 3.5 lbs; which is what one would look for in weight overall for a decent wool coat. but if you compare your coat to pictures of an actual Belstaff worn by Sherlock, you'll notice that the material itself is not as .. heavy as one used in the $2k+ coat.
The coat itself actually flows quite nicely. I bought the coat simply for the desire of something simple/elegant and I really enjoy WIDE lapels on a coat. The only thing I dont like is how the pleats drape on the back; I may actually run it under my machine to get some perma-pleat action going on. Though, it doesn't at all kill it for me. Another thing to note is that the coat is creased here and there from the way it was folded and shipped. The fabric is on the softer side; and I may send the coat to a dry-cleaning service to see if the chemicals and cleaners they use will improve the ..stiffness of the coat.
As far as warmth goes, in 40 degrees Fahrenheit wearing a t-shirt and trousers, I was a bit nippy. And i'm a heavier guy at about 250lb who enjoys the cold. Wearing a blazer underneath, and a scarf around my neck, I was pleasantly comfortable (Sherlock wears a jacket underneath the overcoat, so the idea kind is kind of kept in line). Once, however, you warm up from general walking the coat is quite comfortable to wear.
Being a heavier guy, I went custom as far as the fit goes. I'm a larger guy, so my measurements fall in line for what a 2XL would be. It should be noted with the coat closed the fabric bunches around the buttons a bit from pull. Which, for me as a larger guy is bound to happen. With someone who is more fit this would probably be LESS of a problem. I feel in the future that I may pull the stitching apart; or even have a professional do so, to fit felt in the coat to bolster some areas; particularly in the shoulders close to the neck, the collar, and lapel regions. Just for the ... added "thicknes".
The buttons are actually of surprising quality given that they're made of plastic. I removed mine and moved them in closer to the buttonholes for a less-snug coat. The overall build is actually solid, and more in line with an autumn/early winter coat than a heavy-winter coat. The way its put together is actually quite flawless. Im a professional costumer and I hate having to buy anything from China, but im surprised by how well-tailored this is. It's very comfortable. My only other qualm is that it is BARELY snug in the shoulders. I would prefer something a little looser, but im curious if it were an error on my part with the measurements that I gave.
OVERALL; I'm very pleased with the coat. Those who are looking for the 2-thousand-dollar belstaff quality will not find it here. Though it is a decent-quality coat. My overall wish would be that the material be thicker; which im curious if those who have contacted tssy2005 and the company have made this suggestion at all. I can easily compare the quality of this trench coat to a tweed blazer that I purchased some years ago. And they match. lol.
I do feel that the coat was well-worth the 200 dollars I paid for it.
Oh! It should be noted, I got the coat in exactly 1-week. Pretty quickly, especially since its from china!
Im no writer, so im sorry if I sound weird. If you guys have any questions post them and i'll try my best to answer them. Eventually i'll get around to posting pictures!
Thanks!
Cheers!
