trufunky
Member
Do you have à Link please??
You can google it, there are a million vendors that sell it. It's a sicker so all you'd have to do is stick it onto curved plastic, possibly vacuformed to the shape you want.
All Website that I've seen ask a file for print on it, it's normal ?
Some will actually send you free samples, which would fit a lens perfectly.
If they want a file send them a blank white picture, or whatever colour you want it to be. You can tell them you want it to be all white with no design.
Heres the site I'm planning on using:
One Way Vision Signs, One Way Vision Signs at $0.99/SF, One Way Vision
They offer bulk discounts so instead of getting one big sheet, cut the size you want to multiple smaller pieces, each one can be for a lens. Then you can get bulk discounts on your order.
I'm from Canada so shipping wise this is my best option I've found, you might find better depending on wherever you are.
Hi man !hi what's the dimensions of the spider?
Thanks for your work dude !FYI: I make $0.00,.... nothing, nada when you order ANY of my Spidey or Iron man parts. I also have made them all downloadable files on Shapeways to boot.
Hi man !
And it was not in my intention to sell the ( your ) lenses or any spidey work ! That's why I made my tuto !
As I have stated before, these files are "open source", sell, copy, cast, ... do as you please.
Have fun and good luck!
Hi man !
I have print a spider logo on paper, so it's A4 format, I didn't have the dimension, I can take it when I finished my work if you want
Hi yes please, that would be much appreciated.
if it's also possible, could you measure the black spider as well? I need these measurements to buy a rubber sheet.
Where do you buy the rubber mat?
yes it's good ! 1 mm look very cool also, 3 is too bigI found stuff on eBay that was 2mm (1/16) thick that was neoprene urethane. Is that the same material you used or just urethane?
Thank you Jeck! Your builds are awesome. Keep it up!
