Hello. How do I print a suit pattern? I am new to suit making and I recently decided to make a Tobey Maguire Spider-Man suit. I try to print it but it is very small on one piece of paper. What do I do? Thanks for the help gang.
I am not sure what you are starting with. The terms you probably want to research in general or with regard to your printing software is "poster" and "tile". Taking an image and printing it as a poster allows you to enlarge the image to a much larger format. Then instead of printing it on a single piece of paper you print it as several separate sheets which you "tile" back together. Often you can convert a single image to a pdf format to enlarge and manipulate it. Also some printing centers such as Staples can help you produce large print size posters.
