CosmicQuest
Fasteners might not be a bad way to go. I might give that option a try on a future build. Thank you Drusselmeyer!!Polyethylene and polypropylene are so resistant to adhesion that they can be used as the containers for the adhesives.
If adhesion is a problem, try anchoring the joint using some type of fastener. If both sides of a joint are connected to a part that can join the two areas, the whole assembly will hold together.
You can add screws, pop rivets, tabs or anything that can be glued or fastened together.
At that point, you could use some type of epoxy or other adhesive to connect the parts.
