Subscribe
  1. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Benson (North Carolina), United States
    Messages
    4,202
    Apr 20, 2009, 9:19 AM - Smooth-On resin? Need some help/info #1
    I've got some molds I made out of MoldMax30 and I need to cast the resin pieces. I was looking at getting the Smoothcast 310. Anybody worked with it before and have any suggestions?
    -Matt
  2. RPF Premium Member Skaught's Avatar
    Member Since
    Feb 2002
    From
    St. Pete
    Messages
    3,339
    Apr 20, 2009, 9:25 AM - Re: Smooth-On resin? Need some help/info #2
    I've used 300 to slush cast and normal casting. What kind of advice do you need?
    Scott
  3. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Messages
    4,202
    Apr 20, 2009, 9:30 AM - Re: Smooth-On resin? Need some help/info #3
    I guess I need a recommendation more than advice. Thanks for your input!
  4. RPF Premium Member Hotshot's Avatar
    Member Since
    Apr 2005
    From
    Millersburg, Ohio; the Heart of Amish Country
    Messages
    2,178
    Apr 20, 2009, 9:41 AM - Re: Smooth-On resin? Need some help/info #4
    300, 305, and 325 are all my stand-bys. 1:1 mixes, bright white (325 is a hazy clear, awesome for coloring)
    Just be sure to wear a good mask or respirator, cause thus stuff can build up in your system pretty bad over time.
  5. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Messages
    4,202
    Apr 20, 2009, 9:41 AM - Re: Smooth-On resin? Need some help/info #5
    Thanks!
    I'm this is only a one time usage thing.
  6. RPF Premium Member Skaught's Avatar
    Member Since
    Feb 2002
    From
    St. Pete
    Messages
    3,339
    Apr 21, 2009, 2:15 PM - Re: Smooth-On resin? Need some help/info #6
    Hotshot said: View Post
    Really? Huh...better not take advice from me then.
    Not much too the stuff. Just mix up equal parts, pour it in, and come back in 10 minutes. With slush casting, I pour twice so it's easier to manage. Too much and the weight of it stops to glop around inside the mold before it sets, resulting in an uneven interior. I wait until the first pour stops moving, but before it's completely set, then pour in the next layer. The second pout seems to cure faster, whether from the heat of the curing first pour or because the chemical reaction in the first pour affects the second, or both, I don't know. But since the second pour is just adding thickness, the quicker the better.
    Scott
  7. LeMarchand is offline LeMarchand
    Apr 21, 2009, 4:17 PM - Re: Smooth-On resin? Need some help/info #7
    I use 300 for smaller casts as it kicks fairly fast and 305 for bigger molds. Make sure you stir/shake part B wel before mixing. Not stirring part B properly before adding a+b together can reult in uncuring resin that will kill your mold (trust me, i have been there)
    If you don't have the option to degass your resin prior to casting or do pressure casting and you decide to use 305 or 310. Shake can B firmly and let it be for 30-45 minutes. You will then have a good part B and most of the bubbles that have been introduced into it will have risen to the surface.
    Personally i love this resin.
    Cheers,
    Marc
  8. RPF Premium Member stormtrooperguy's Avatar
    Member Since
    Nov 2003
    From
    Waltham, MA
    Messages
    1,920
    Apr 21, 2009, 4:19 PM - Re: Smooth-On resin? Need some help/info #8
    for slush casts i always use smoothcast roto. the 3xx series is too brittle for my tastes. i've dropped roto helmets onto concrete and at worst had a minor chip, usually nothing.
    solid stuff i usually end up using roto as well, since i have it. i can toss, say, a firefly message recorder across the room without damage
  9. LeMarchand is offline LeMarchand
    Apr 21, 2009, 4:26 PM - Re: Smooth-On resin? Need some help/info #9
    Is the smooth-on resin good for regular casting too? How does it compare to their 'Task' series?
  10. Kwally89's Avatar
    Member Since
    Jun 2008
    From
    Iowa
    Messages
    374
    Apr 21, 2009, 4:37 PM - Re: Smooth-On resin? Need some help/info #10
    tk7602 said: View Post
    A lot of people use smoothcast 300 for slush casting, but I have always loved smoothcast roto. It is VERY easy to work with and you can pull great casts with little effort. If you are looking to do solid pieces, I like smooth-cast 325. It has a short pot life, but you can demold the casts in around 10 minutes.
  11. RPF Premium Member Skaught's Avatar
    Member Since
    Feb 2002
    From
    St. Pete
    Messages
    3,339
    Apr 21, 2009, 4:45 PM - Re: Smooth-On resin? Need some help/info #11
    I've used 300 for both slush and normal casting. I dropped one of my IG-88 heads and it bounced with no damage. And these are 1/8" thick. Solid stuff.
    Scott
  12. fettster's Avatar
    Member Since
    Dec 2005
    From
    Solihull, West Midlands
    Messages
    2,262
    Apr 21, 2009, 5:30 PM - Re: Smooth-On resin? Need some help/info #12
    hi Matt, is this for what i think it is?
  13. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Messages
    4,202
    Apr 21, 2009, 8:35 PM - Re: Smooth-On resin? Need some help/info #13
    Actually it's not, lol. I've got some SmoothCast 300 on the way for these pieces. If it will work for what you requested I will give it a try.
    -Matt
  14. RPF Premium Member Hecubus114's Avatar
    Member Since
    Dec 2005
    From
    Phx, AZ
    Messages
    2,005
    Apr 21, 2009, 10:25 PM - Re: Smooth-On resin? Need some help/info #14
    is it for what I think it is, LOL???
  15. THStudio is offline THStudio
    Apr 21, 2009, 10:35 PM - Re: Smooth-On resin? Need some help/info #15
    You can use Smooth Cast 320 as a surface coat for Roto resin castings. I've done that before with great success. Just dont waste time between layers so everything adheres. Didnt have delamination, or any problems.
    The resin why I did that was to create a bit of a harder surface, which still allowed a great deal of flex. Normally, for me the surface of roto pieces are too soft, as the resin cures softer than what you might be used to.
    Tyler
  16. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Messages
    4,202
    Apr 21, 2009, 10:36 PM - Re: Smooth-On resin? Need some help/info #16
    Hecubus114 said: View Post
    Both of you want the same thing
    I'm workin' on it I promise.
    Thanks Tyler for that info!
  17. fettster's Avatar
    Member Since
    Dec 2005
    From
    Messages
    2,262
    Apr 22, 2009, 7:08 AM - Re: Smooth-On resin? Need some help/info #17
    The Batman said: View Post
    If your thinking what Im thinking then Matt is thinking he thinks he knows what we are thinking. I think
  18. Yodajammies's Avatar
    Member Since
    Jun 2008
    From
    NashVille, TN
    Messages
    460
    Apr 22, 2009, 9:01 AM - Re: Smooth-On resin? Need some help/info #18
    Not to thread-jack but, I've had a lot of experience with smoothcast300 and found it to be a bit brittle. Does smooth on offer a product with properties closer to that of a frisbee? A lower durometer rating?
  19. Jawafive's Avatar
    Member Since
    Aug 2002
    From
    Messages
    4,202
    Apr 22, 2009, 9:11 AM - Re: Smooth-On resin? Need some help/info #19
    fettster said: View Post
    Brain hurts!
  20. RPF Premium Member CSMacLaren's Avatar
    Member Since
    Mar 2007
    Messages
    2,024
    Apr 22, 2009, 10:27 AM - Re: Smooth-On resin? Need some help/info #20
    How workable is the roto material? If you have to cut out, say, eye slots, does the material sand well or does it remain squeaky, rigid and intolerant to any modification?
    Also, how heat resistant is it, or will things start to "melt" if worn too long out under the sun?
  21. RPF Premium Member Hotshot's Avatar
    Member Since
    Apr 2005
    From
    Messages
    2,178
    Apr 22, 2009, 12:49 PM - Re: Smooth-On resin? Need some help/info #21
    The roto's awesome. It sands up and cuts as well as the 300 series. It stinks though!!!
  22. RPF Premium Member Skaught's Avatar
    Member Since
    Feb 2002
    From
    St. Pete
    Messages
    3,339
    Apr 23, 2009, 10:50 AM - Re: Smooth-On resin? Need some help/info #22
    CSMacLaren said: View Post
    I have a patch of 300 that I spilled on my outside work area. It's been in the sun for abotu three months now. Other than turning yellow, it's as hard as it ever was. I've chiseled some of it off, but it takes a thin layer of concrete with it.
    Scott
  23. RPF Premium Member stormtrooperguy's Avatar
    Member Since
    Nov 2003
    From
    Waltham, MA
    Messages
    1,920
    Apr 23, 2009, 11:36 AM - Re: Smooth-On resin? Need some help/info #23
    Yodajammies said: View Post
    that's the smoothcast roto
Similar Threads
  1. Replies: 1
    Last Post: Aug 8, 2014, 11:01 AM
  2. New Smooth-On Black Resin
    Rebelscum, Replica Props
    Last Post: Oct 11, 2013, 2:40 PM
  3. Fiberglass Resin vs. Smooth Cast...again
    Ibnzbass4, Replica Costumes
    Last Post: Sep 6, 2012, 2:48 PM
  4. Smooth-on Crytal Clear resin home use?
    CasterTroy, General Modeling
    Last Post: Dec 16, 2010, 7:58 PM
  5. Replies: 8
    Last Post: Nov 26, 2010, 11:22 AM
