1. Bloop's Avatar
    Join Date
    Dec 2010
    Message Count
    124
    Apr 27, 2012 - Mini Ennis House Tiles - Blade Runner, Rocketeer etc #1
    So I've been working on a miniature bust of Deckard from Blade Runner (seen here: http://www.therpf.com/f62/blade-runn...update-112421/). I finally figured out what I wanted to do for a base, which involves using the Ennis House tiles, seen in Deckard's apartment:
    The tiles are from Frank Lloyd Wright's Ennis House, which pop up in other movies and tv shows, like The Rocketeer, Farscape, and Buffy The Vampire Slayer, to name a few.
    So, I wanted to make some on a small scale. I decided on 1.25" x1.25". To make them, I started with an image of a 3D Sketchup version found here:
    ENNIS HOUSE STYLE TILE 3D by ZALVEZ - Google 3D Warehouse
    I adjusted the image a bit, reversing it, as it would be a mold:
    I printed the image out multiple times on 110lb card stock. Then I cut out each layer as needed and super glued them onto the flat image, building up the layers to get my mold:
    To help me build up the layers properly, I came up with this image to help keep track of the depth:
    I went in "rainbow" order of depth: red is the deepest, then orange, yellow, green, cyan, blue, purple, then finally white as the shallowest. In case it's confusing, I added one layer of card stock for every color level. So red was the bottom layer, orange is 2 layers of card stock, yellow is 3 layers and so on.
    Finally, I rolled out Super Sculpey clay, pressed it into my mold, and got my tile! After making a bunch, I boiled them in water to harden them up.
    They're far from perfect, and some warping occurred, maybe the clay needs to be thicker. I didn't do any cleanup on them yet either. They're kind of rough, but I think they'll work for my needs, especially at this small size.
    Anyway, just thought I'd share a cheap, relatively easy way of making these. The good thing about this is it's easy to scale up, as long as you increase your thickness of layers accordingly. I was thinking of trying this full scale with regular cardboard.
    Attached Thumbnails Attached Thumbnails ennis_tile.png   ennis_tile_reverse_levels.png   ennis_tile_and_mold.png
Similar Threads
  1. Ennis House Tiles from Blade Runner
    sstinson, Replica Movie Props
    Last Post: Jan 15, 2013, 4:21 AM
  2. Blade Runner WIP - 6" Ennis House Block
    wolff, General Modeling
    Last Post: Dec 9, 2011, 2:24 AM
  3. Mounting Ennis House Tiles
    JayPHX, Replica Movie Props
    Last Post: Jul 10, 2011, 11:30 PM
  4. Full Scale Ennis (Blade Runner) Tiles
    Gordon Gekko, Replica Movie Props
    Last Post: Jun 16, 2011, 12:46 PM
1 2 3 4 5 6 7 8 9 10 11
