MTB
I just wanted to show everyone the latest project I have been working on. I wanted to make the Power Sword for a while now, I decided to make it like the one in the 80's cartoon. This the picture I based my build off of;
I started with a basic out line of the sword on that thin cardboard/wood sheet (sorry dont know exactly what its called)
After cutting out the outline I glued green floral foam blocks on to it.
Then cut out the basic shape
and yay! back to sanding, would have though I had enough of that with the Iron Man lol
after getting the correct shape I applied fiberglass resin to the foam then bondo over it, and once again more sanding!
Yes that is a pee pee pad in the pic, my daughter was being potty trained at that time =)
Here is a picture to show the size of the sword. That Iron man is about 5' 7 just to give a reference.
I still have more bondo work to do, My plan it to cast it out of plastic with a metal rod up the middle. The only problem is I dont have the funds to spend to make the mold. I have been looking around for cheaper methods of mold making, I came across this Easy, Illustrated Instructions on How to Make a Cheap Silicone Mold with Ordinary Silicone Caulk but not too sure if it would work out.
As always any suggestions/ideas are welcome!
