chazdragon
I am planning on sculpting a full venom body suit but have never taken on a project of this magnitude and have some questions as I am trying to decide on how to best build the piece. I know the clay sculpt is ruff right now. I have built it on a fiberglass and aluminum frame so that the jaw will move with grate ease. I first designed a pulley system and quickly abandoned that idea I then looked into solenoids and decided that would not work well for realistic motion. I finally settled on elastic bands with a formed chin rest (keep it simple stupid). The aluminum platform in the jaw will also serve as an anchor point for a motor that will make the tong flop on command. Tubing will be run from a reservoir with a priming pump to the mouth so that I can simulate salivation. I will share my specs for the co2 powered web shooter after working out the kinks. In the mean time my questions to all of you are as follows:
1. Should I make it out of silicone or latex.
(I know silicone would look more realistic but I am worried about seaming such a large suit together as I have not seen any video posts on how to do it )
2. If I want to sculpt the hands how would I use the silicone with a two piece mold. (poring latex would be much cheaper and easier but won’t move as well)
3. Should I keep with the tendril look (the symbiote fusing with Brock or should I scratch that idea and keep with the traditional full suit. Take a look at some of my ruff sketches and let me know what you think.)
I know my first sculpt looked more like the violator than venom. (Hence the change.)
the third pick is the tendrils taking over the left side of the face (still needs a lot of work) (the teeth will be changed out this weekend for molded pieces)
Web Shooter pre-plans
A hollow chamber for loading my "webbing cartridge" will be disguised by venom's classic white rectangle located on the back of his hand. a shark bite coupling will be used to secure flexible nylon pressure tubing to the chamber on one end and a 16g co2 pump/ discharger on the other. The Co2 pump will be in-closed in the control box disguised on my hip. The "Webbing cartridge" will contain a specialized streamer pack. The control box will also house the primer for the saliva tubing and the toggle switch for the tong motor.
worked on the jaw and eye tonight.
starting to look like venom. but still needs work
Looks like it is time to do the rest of the body.......
