HorrorChix89
the goggles that glasscannon posted are very identical. But for that price I think I'm better off making a some sort of prop of them (it'll look homemade but might save me some money in the mean run)
Those sites made my life a little easier. I was just about to ask about the belts. The main buckle looks to be bent at the prong. Might be a little tricky to do by hand but not too hard I suppose.There are lots of Mk 8 knock offs on eBay and a couple mk 49 knock offs. Just search for RAF goggles or humvee goggles, that should give you a cheap starting point.
The crisscross belt for the shoulder harness looks to use
Tandy Leather Factory - All Purpose Strap Buckles
Tandy also carries the pyramid spots (1331-xx)
The primary buckle and the double prong buckle on the gauntlet I don't recognize.
The harness looks to be put together with triglides/adjusters. I believe metal because they are not rectangular, but they look more rounded than the more common stamped type, but less round than others.:wacko
I think these are pretty close, but I know nothing about the vendor.
Metal Tri-Glide
Glad to help.Those sites made my life a little easier. I was just about to ask about the belts. The main buckle looks to be bent at the prong. Might be a little tricky to do by hand but not too hard I suppose.
Guessing size would be a fun job![]()
Yes, the reference photos we have to go by don't so much and it seems like in every one of them something is a little different. If Gentle Giant had made a statue of her then I could go by that. And on the down side, I still don't know what the back of her looks like!Glad to help.
Guessing the size would be made much easier if we knew what her sidearm was. Or they could be scaled off the goggles or the tomahawk.
The main buckle appears to be a center bar buckle with the left side attached to the normal top of the buckle rather than over the center bar.
Have you noticed the pyramid spots on her left shoulder. There seem to be Two rows of three next to each other rather than the typical two rows of two with a gap. Unfortunately every shot you can see the 2x3 spots you can't see any of the others. So I don't know if it is a single difference or a second harness with a continuity error.
Wow, awesome job on identifying the pieces so far! I'm curious about the blocky pieces that look like they're part of the side of her harness(?) in that above pic.
The chest looks like thin neoprene or a smooth pleather (probably pleather), the center grey panels could be microsuede & the outer grey panels look like wool, I think the texture is called crepe.
Here is a shot of wool crepe.
Wool Crepe - Blue Grey, IF710W-07 :: Wool Crepe Fabric :: Wool Fabric :: Fabric By Content :: Vogue Fabrics - America's Premier Fashion Fabric Store
edit: You may want stretch crepe.
Edit 2: The center panels may duplicate the pleather from the chest, and it is just the lighting that makes them look different. In the photo with the white background the two chest and center look the same.
I might cheat a little with the zipper because it is kinda weird. Maybe this weekend I'll go down to the dance store and pick up a leotard and get started on a rough draft (so to speak) of the body suit. We'll see how things turn out.It would be easier, and based on the wacky way the zipper is attached at the top it seems the most logical approach as the entire front panel seems to be an onlay anyway.
