Edge of Tomorrow Jacket Technology Suit
I Have started molding and casting. I will be doing this for all the final parts.
I have done some testing, from left to right original, smooth on fetherlite, onyx, and aluminum cold casting powder
I decided on the fetherlite with the aluminum casting powder.
Some very cool research done the mounting system for the feet found.
It looks like for the feet they used snowboard bindings with the back removed.
The closest on looks I could find where these.
Amazing work !! A joy to follow this post . It's coming together very well , thank you for sharing , can't wait to see the final suit .
I have been looking for the hing for the thigh plate cover.
Not being able to find the correct one i decided to make one in CAD. I will be ordering it thought shapeways, then casting and molding a set for the plate hinges.
I have been looking into the function of the joints of the legs and hydraulics. To solve this i decided i needed to do 3d printed parts. I looked into cost and actually found it will cost me less for just this project to buy a 3d printer than to continue using my wood working tools just in materials The more i did the more i found that i would be worth it to just do it all 3d printed. So i have been using my cnc layout to give me direction in making STL files.
I started printing some of the fist parts to get the idea how they will cast and mold.
I looked at the finished surface and found the print lines to be not up to the standard i want i started testing finishes.
I used bondo putty 907, Dupli-color primer filler, some sanding, and krylon gloss blue and the finish is actually better than my cnc parts so i will be continuing with this method in mind for the rest of the parts.
I finished the molds for the attachment for the hydraulic hose(the hose is Thera-Band)
I also got the mechanical parts all working together for the knee joint.
Update on two things the flexible hip cover and the template for all the hydraulic rams.
Hip cover was done with a 3d printed injection type mold with Smooth-on Dragon Skin 10 NV and black silc pig dye.
The hydraulic ram is done with aluminum tubes and then 3d printed additions to make them into the correct ram type. The Hydraulic hose attachment i molded and cold casted with aluminum.
