My DeAgo Falcon
Little Update up to issue #69
Upper frame finished and batterybox installed
collected hull-parts up to #65
due being a little glumsy, I had to re-order issue #2, 5, 6 for a new turret and cockpit :p
#66 - 69 arrived today, so todays work:
*engine cover assembled
*3 recesses assembled
*rearranged the window frame on the replacement turret
*replacement cockpit assembled ( will insert the interior when I primed and blackwashed everything, maybe even coming weekend )
Issues #70 - 73 arrived this week
* removeable jaw section assembled
* sensor dish assembled
* all upper hull parts primed and main color panels ( grey and red ) added. All the othe panels ( light grey, yellow... ) wiil be added during weathering
Next steps the next days: black wash everthing, install to the frame, start weathering
Continued a little on the Falcon
* weathered up and mounted the pits
* assembled the cockpit
* dry-brushed the hull with my main color. I didn´t bother about the engine cover yet. I might do the detailweathering to the rest of the hull first before I concentrate on the engine area.
After a really long break, I finaly found enough motivation to continue on the Falcon and started with detail-weathering on the upper hull. After 4 hours the right hand back quarter is finished so far.
Unfortunatly I had to quit earlier as expected, due almost all of my current brushes are literally dead :) Need to pick up a new set the coming days.
So section finished minus cockpit and tube
At last, the cockpit is finished so far :)
and here it is, my finished upper hull :) :) ... so far
As mentioned somewhere earlier, I will do the engine cover later when the first plant-on parts start to arrive. The sensordish will be done later too, when both shells are combined and I don´t need to put the upper one on the support structure anymore.
Next step: I will start building the first of the mantibles
And here we have my latest update :)
Just finished building and priming the starboard mandible. Headlight installed and it works :) Looks a little blue-ish on the picture but its less blue in reallity
I have to check for some more reference material first before I start weathering the mandible.
And here we have my current progress up to issue #81
uhm yeah, just noticed too and I dont really know whats happening here ..
EDIT: fixed, should show up now ;)
Your weathering job is looking absolutely beautiful. One of the best I've seen. Like it's been said for years, the paint/weathering is what really sells the falcon, regardless of the accuracy. I am really loving your falcon so far.
Latest delivery arrived up to #89
Mantibles main build finished
Interrior and electrics installed
Checking the lights. Landing light, turret and engine
Just curious, to cover the dark spot in the middle of the engine, would it work to cover the complete area around the light with silver electics tape ?
Will start painting the mantibles the coming days ;)
