Drac
Drac,
<snip>
''it seems I can just hook the LEDs straight to the speaker''
<snap>
Since early on, you chose to go with the EL light source, what LEDs are you wanting to connect to the MP3 player speaker output?
The MP3 player output to the speaker is indeed a fluctuating voltage/current from the on board amp designed to drive a 4-8 ohm load
coil in the speaker at 10W.
Adding any number of LEDs straight to the output will effect it's function and sound quality by putting a different output load on the amp.
Not to say it can't be done.
However, the LEDs would require a specific series resister in line so as to not overload them and possibly driver transisters to further
isolate them from the amp output and lesson the load on it.
Also, the volume set by the amp will effect the speaker loudness AND the LED brightness at the same time.
Even with all the precautions, it still would be a bit risky.
Having a separate amp/speaker and light setup would be the best and not effect each other.
Ah so not the best idea then, I am happy to go with the EL light source but I can't figure a way to connect the sound side to the light side using the parts I found, as I say I know nothing of electronics.
ill possibly get the EL and the following:
https://www.quasarelectronics.co.uk/Item/cebek-tr-21-mp3-player-module-for-micro-sd-card-5w-rms
and conmect a speaker and a sensor see what happens
