N2darkness
The first thing to say about vacuum chambers is to NEVER under estimate the power of a vacuum! You do not want to be around a chamber when it implodes, I speak from experience here. My first DIY chamber imploded because I didn't know what I was doing. I was standing only two feet away from it and was lucky to have not sustained any injuries. A real "brown stain moment" if you know what I mean!:eek
Some people have made pretty good vacuum chambers from heavy duty professional kitchen stock pots, the kind that are made from 1/4" thick aluminum, and a Lexan (polycarbonate) cover. I recommend a 3/4" or 1" thick polycarbonate cover over acrylic. Less likely to break or shatter. www.bestvaluevacs.com sells these kind of chambers. I've not had any direct experience with their products but that look pretty good and are reasonably priced.
For a vacuum pump you must get one that can pull a vacuum of 29 inches of mercury, or else you're wasting your money. Many cheap pumps that you'll find on EBay won't pull that high.
Good luck!
All excellent information in this thread and I really appreciate the effort put in here DaveG.
I to am looking to get a vacuum chamber, any recommendation on sizes for both the chamber (1,2 or 5 gallon?) and the pump (1 stage or 2 and 3,4 5 CFM)? There are lots of choices and having a hard time deciding as I only want to buy this once.
