Re: Grommash by Alphatech Last Page new updates on "The Hand" 07/26/16
I just realized I never posted these. The Chain. That is crazy I just saw the date on this. I sculpted this almost a year ago and I'm just now getting it mounted.
After doing a study of chains I found out that when chains start to fail the long sides start to collapse inward so the piece across the center helps to prevent the failure. There is your lesson on chains. I just thought it looked cool.
Getting it ready to mold
Poured up in Smooth-Cast Onyx
Had to sculpt pieces to connect the chain to the back of the belt and to the bandolero.
Here is that piece to connect to the bandolero after the paint. I had sculpted the rivets then later decided I would connect it to the leather with real rivets Sometimes you have to adapt. Test fitting the rivet. I tried to drill through my finger earlier. My wife thinks I'm not careful. What does she know.
One of the first steps of the painting process is a coat of Killer Chrome. This stuff is awesome
I started working on this little piece when I realized I needed to be able to disconnect the chain from the belt. I found this little purse clasp that looked like it would work well.
I fabricated this aluminum base to except the clasp.
From the backside of the belt.
I had to do a little re-sculpt over the areas where I connected the clasp.
It was also time to mount these medallions .
I guess I have to much time on my hands. I decided to bolt these to the shoulder piece so I fabricated a couple of pins and mounted some earth magnets to hold the skull onto the medallion. I wanted to be able to get at that bolt. I will probably wind up putting a couple of drops of glue on it anyway. It was a good exercise.
So here is the finished deal. Ok almost finished I still plan on finessing the rust effect on the whole thing.
That is all for now. I am still putting in many hours finishing the articulating hand. It has been very interesting. I think everyone will like the finished product. Thanks for checking out my build.
Re: Grommash by Alphatech Last Page updates "The Chain" 21 new photos 08/12/16
Here is the latest on the hand build.
A couple of photos on the almost finished piece.
Here is an early test with the linkages
The structure of the finger done with 1/8 PVC. I love this stuff. Super glue bonds with it completely. The PVC breaks before the bond. I used Chicago screws on everything. They worked great for things like this because they come in 1/8inch increments so they tighten perfectly into place.
Casting the knuckles and finger tips. They were done in Feather Lite Resin from Smooth on.
These are the finger controls. They are made PVC couplings. The hands I have seen like this had the finger controls just hanging in place. I decided it was a good idea to connect then to the hand creating a fulcrum. It works really well.
I was at the point when I needed to make the pinky. If I was at work I would have just placed the drawing in the copier and reduced it but I was not at work. I thought some of you might think this was interesting. I placed one copy of the drawing on my glass table and another of the same drawing on the chair under the table. I then placed a clear piece of plastic next to the drawing on the table. I had to close one eye and adjust where I was positioned then traced the lower drawing onto the clear plastic. I know it is weird but it worked.
Some closer looks at the fingers.
People that know me will appreciate this photo. I heated up this coupling and stretched open one end so I could get my thumb in it without removing my rings. I just wanted to see if it could be done.
I decided to place a solid bar to hold my hand in place. I wanted to be able to just slide my hand in an go. By the way the total weight is 2.3 pounds. I'm planning on doing the glove in silicone so that will add quite a bit of weight. I'm doing my best to keep it lite.
Lastly a video of the movement. Sorry for the poor quality it had to be crunched when I texted then emailed.
Re: Grommash Build. Last Page finally some updates. The axe (Gorehowl) 12/16/2016
On to the molding. I decided to mold this without dividing the sculpt. I brushed on Mold Max Stroke for 2 thin coats then one on coat thickened with cabosil. I did one coat of Epoxacoat fiberglass on each side for the mother mold (mold jacket). When it was ready I carefully used an exacto knife and cut along the edge of the blade and then all the way around.
While the fiberglass was curing I started on the handle. I actually made 2, one in styrofoam and one in wood. I am making a second one for a friend to bribe him to help me at a comic con when ever I get this done. I shaped the styrofoam then covered it with on coat of fiberglass. That worked great. The second one I cut a piece of plywood then glued and clamped the 2x6 cut outs to the plywood. I shaped that on my belt sander with 50 grit paper. That worked great also.
This was interesting here. I decided to dremel the edges of the fiberglass while the piece was still in the mold. I figured because I cut the mold if I dremeled it right to the edge things might fit together when I was done. I was right. The pictures of the seams were not touched once I took the pieces from the molds.
Next I super glued the leading edge then packed a bead of Feather-lite epoxy putty behind it. This might have been overkill. Then I slipped the top of the handle in and glued the rest of the edges. The picture shown is just to show how the handle fits in place in the axe head. Next I positioned the handle where it needed to be and filled the head with 2 part rigid foam.
Here is a picture of the Blizzard statue axe and mine so far.
I will get the axe skull build up very soon. That is all for now.
Thanks everyone for lookin in. Here is the latest. I molded and cast the skull.
First of 2 thin layers of MoldMax Stroke.
One thick layer of Mold Max Stroke mixed with cabosil.
Next was one layer of Epoxacoat Grey and one layer of Epoxamite/fiberglass.
I then cleaned out the clay and brushed in one coat of Epoxacoat Grey in all the areas except where the skull was. I did that in white resin just because I wanted the base of the skull white for wear purposes.
Then I mixed up a small amount of Free Form Air epoxy putty to fill in any deep groves to make laying up the fiberglass easier later and for weight. I believe the fiberglass resin would fill these areas and add more weight. Free Form Air is very lite weight.
Then came the Smoothcast 305 white. I mixed 4 small batches one at a time and rolled them around until they kicked.
This might be overkill but then I mixed another small amount of Free Form Air and backed up the skull area with it.
Finally I laid in one layer of Epoxamite/fiberglass.
These are pictures of the pull right from the mold no trimming or cleaning.
Test fitting on the ax. like a glove.
So now I'm working on the spikes. Slow and steady wins the race.
Re: Grommash Build. Last Page Minor updates 12/26/2016
Haven't had a lot of time but I have gotten a git more done.
Getting the basic base.
Here's something I never tried before. I was trying to figure out the best way to make these forms on the butt piece. I decided to draw the profile on a piece of plexiglass and cut it out to make a "drag stencil" for lack of knowing what else to call it. It worked pretty good. these 2 pictures are with no clean up yet.
Sadly that is all for now. Oh yea I am planning on doing a cross between the newest Gorehowl butt and an older version.
This is Steve Wang's version.
Re: Grommash Build. Last Page ax head put together 12/30/2016
So here are some progress shot of the butt sculpt.
First is the sketch I did to get an idea of what I was doing.
This is how I sculpt symmetrical things. I sculpt one then rough out the other one and attach them. I keep flipping them around and shaping until pretty soon I don't know which one I started with.
Here is the Blizzard ax butt with the spikes in the back ground.
Ready for molding
Pulling the first spike out of the mold. I molded and cast these so it would be easier to place them and sculpt around them.
Starting to get the details down
Getting down to the final surface details, casting flaws,rust, battle damage etc.
The final sculpt.
Here's a couple with the spikes in place.
That's it for now. Hopefully tomorrow will be molding this. Thanks for checkin thinks out.
Re: Grommash Build. Last Page Axe butt finished sculpt. 16 new pics. 01/05/2017
Alright so I got the head smasher molded and cast. I molded it in Mold Max Stroke, 2 thin layers, one cabosil thickened layer. I decided to try something little different, when the last layer was starting to thicken I pushed in this shim stock bent at 90 degrees. This was to divide my mother mold. First I PVAed the shims then 1 layer of Epoxacoat and on layer of Epoxamite/fiberglass.
I used an Exacto and split one side of the silicone and opened it up.
The mother mold
Everything reassembled and ready for SmoothCast Onyx.
Right out of the mold.
Once I glued the spikes in place I drilled and pinned them. I always have to "Tim Allen Tool Guy" things
The finished piece before paint. I still have to make the second one. I poured this one solid to go on the wall mount ax that is for a friend.
Here is the wooden handle for the wall mount. I made this whole thing heavier than the one I will carry. I don't know why, I guess I just wanted it to feel good when someone holds it.
