Re: Thorssoli's Episode VII Builds
Mind still blown.
Eagerly awaiting your "lens" method.
Me as well. I'm about to form my own and could do with some learning from @
thorssoli;
I guess I couldn't have asked for a better setup than that.
Here's how the lenses are made:
I start by casting a particularly thick copy of the area around the eye holes:
I cast this particular copy in plurple because YOU'RE NOT THE BOSS OF ME:
With the cast copy out of the mold, I cut a nice, level slice off of the top:
Then I mark a line parallel to that one, but under the eyes so I can cut that part off too:
Then I cut the ends square so it'll sit flat on the bench while I cut out the eye holes with a tile cutting bit on the Dremel:
After a bit of touch-up with the sanding drum, the eye holes are nice and smooth and ready to go:
Then I build a box around this piece of the helmet:
The circular hole is where the shop-vac will be attached later.
After gluing the faceplate in place and bonding all four sides together, I tape off the edges, set the whole thing upside-down, and pour in some resin to seal the edges:
Then I glue the last piece of plywood in place to seal up the bottom and flip the whole thing upright again. Here's the view from the top:
With a tool adaptor screwed on and a descriptive label, the lensmaker is ready to go:
Now it's time to cut out a strip of tinted acrylic and cook it. For little pieces like this, I use a toaster oven:
Acrylic is porous and the surface pores tend to fill up with moisture from the surrounding air. This means it needs to be pre-dried at about 100°F for a few minutes before cooking it to forming temperature at about 400°F for a few more minutes. Eventually it gets hot enough that it'll flex and stretch a bit:
Then it's time to place it into the vacforminator and turn on the shop vac:
The acrylic is sucked into the hole, but only so much. The shop vac stays on until the plastic has cooled enough to keep its new shape. Then I shut off the vacuum, pop the lenses out, and stick them in a helmet. Then I take a selfie:
If you want the lenses to be more convex, it's just a matter of making the plastic softer by cooking it a bit longer.
And that's how lenses are made.
