judgedredd
where do you get the clamp covers?
That looks like it took a fair amount of work. Can anyone else that's performed the same calculations verify these numbers? I haven't yet, but surely someone else has also tried to figure these dimensions out...
Does anyone here know if Maz's lightsaber has the turned glass eye like on Finn's?
I did. Please check post #2390
I will make, one day soon, make new blueprints from these.
No, it doesn't have that.
I'm coming back to my earlier statement that Maz's lightsaber doesn't have the smooth turned glass eye.
This image might be the only moment a small corner of the glass eye becomes visible and it shows brass!
So, it seems that both sabers have the same detail.
Note that the transparent clamp card with the left-sided thin traces are clearly visible here.
Roy
I think you meant to type "does", not "doesn't".
Is that how your reworked clamp card will look Roy? Also is there any chance that you can also offer a run of the smooth glass eyes?
Just buy a second one from saberbay and you can switch it out whenever you want. They sell one that is already machined down to brass: https://www.etsy.com/listing/400435...lica-graflex-glass-eye?ref=shop_home_active_1
