A few updates...
NEW DECAL: Found a 'hidden' decal, well just hard to notice, on the bottom aft of the landing gear box, on the starboard side is a fin sticking out (there is one on the other side too) just to the port (inner) side of it is a 'cummings powered' logo, well what looks like the bottom half of one, just the black and yellow stripes portion...it lays side-ways port-to-strbd...
now look at this image...
...you can see a few things here, first, there are two
new #12's that are not on the tracker sheet, just port of the
#12a that is tracked...also, in the tracker
#152a &
#152b are listed as having white between the stripes, in this images (and others) there is NO white, it appears that in some photos (mostly the ones in Steve's archive) the clear base of the decal is being reflective and giving the impression of white (reflecting light)...and, there is one more
new one that is not found in the tracker, more forward along the center, that looks to be the same type of decal as the one close to
#12b...which is
#161 on the tracker I believe...it looks like more of the same black text...but I need better views...
Another new one that seems to have been missed on the tracker is a small yellow text block found on the starboard mandible, on the top outer surface of the
'shield generator' chassis box that is next to the inner access pit...it looks similar to
#62 but it may be one of the others from the same microscale RR sheet...
...one other one to point out...it seems that the decal at the bottom center front end of the lower 'jaw box'...in front of the two long black stripes (
#119) and the red 'cresent winged' arrow (
#155) ...is two yellow boxes, just forward of them...these are not tracked, and I am still unsure what they may be exactly...they could be two more
#62's?...need to look for better images of these, if any one has better shots of this area please let me know?
Well thats it for now...keeping it going
imurme
p.s. Robert, I'm sending you an edited tracker with some suggestions for improvements for you to go over.
