HEILANDER
Thanks for the quick reply, halliwax!
The thing about Roman's clamps is that they don't always fit the Parks Graflex properly. I have a friend, who I won't name on here, who had a horrific experience, and ended up butchering his clamp trying to get it on both halves of the Graflex, (whilst following Roman's instructions on how to adjust it with plyers). There was enough of a size discrepancy that once it was around the graflex, the lever no longer aligned with the thread it screws into, and no amount of realignment would get it to reach. It's hard to explain. But in any case, this has made me hesitant to order from Roman myself. Has anyone else here successfully used Roman clamps on a Parks Graflex? Maybe my friend's clamp was a strange aberration and not indicative of Roman's usual work.
http://www.therpf.com/showthread.php?t=228132&page=20&p=4012817&viewfull=1#post4012817
This is where someone posts about the divots (and someone else chimes in to say theirs had the same problem). It's encouraging to hear that you've not encountered this issue though
Sorry, I didn't mean the TFA bottom plate, but rather the entire bottom piece that the grips attach to. The holes I'm nervous about drilling would be the grip ones.
And speaking of rivet holes, what you've said about the accuracy of Roy's rivets is very encouraging.
1. Parks clamp may not be as accurate as you are lead to believe... roys clamp cover matches the vintage clamp 100%. if you grab roys clamp cover and place it over the parks it MAY not line up correctly with the square holes and long oval... SOLUTION: grab a vintage clamp for your replica, or buy a 100% accurate clamp from roman, romans clamps and roys covers fit flawlessly
2. this is surprising to me? i practically live on this site and i have never heard of this? i have about... 5 covers from Roy with 1 new one on the way. bought in batches at different times. I dont mass produce sabers, im just a greeblie saber junkie.. i collect these pieces like art work i guess we can say. NONE of my covers have these so called "divots" they are flawless. and if i did have a divot i have no doubt Roy would stand behind his product 100%. Roy is an awesome guy, who i trust entirely
3. i drilled all mine with out a drill press. the first grips i drilled i didnt even use a center punch... but the center punch made my world a whole lot easier.. i double and triple check everything... as for buying a new bottom why? Roy sells the TFA bottom cover plate which will cover up any previous rivet hole issues you had before?
