Hasbro Hero Millennium Falcon Modification
Just as a piece of information - I tried Rustoleum automotive primer on the inside of mine and it worked pretty well... tape was not taking it off. I even scratched it with my fingernail and while it left a mark in the primer it did not release form the plastic.
in case it helps someone else :)
Jedi Dade
Jedi Dade
Good info Jedi Dade!!!
Thanks for sharing!
What happened?.....did it peel off?
I've been doing a bit of painting also:
I cut the lower half of the cockpit tube & attached it to the rest of it
I've got the Revell TIE in silicone so hopefully it will mould alright
Thanks for looking
John
These conversions are coming along so well. I can't wait to get back home and hack into mine. Even just opening up the cockpit does wonders for the look of this. Hasbro have been hit and miss on many things lately but apart form the plastic used in this this is definitely a winner for modelers. Just not for the kids who want to play with it.
How much did the Hycote spray cost you John? Can't find it locally and online seems very expensive? Also what glue are you using?
Just a heads up
JB Weld doesn't really "glue" things together. I hardens. You can sand it down to smooth corners but it unless it is into a groove, if you twist the attached sites they will pop away.
I've cut away the side-wall, It looks to me, because it was designed to have a sticker applied, to be not as deep into the mandible as I'd like.
Attaching greeblies to this wall would in turn make the details too prominent, unlike the pre-greeblied section beside it.
As usual the plastic is easilly cut & removed:
I've also removed some of the details on the Jawbox
Thanks again for looking
John
Very brave and inspiring!!! :thumbsup
(reminds me of when i cut out the dash board on my delorean)
http://i1119.photobucket.com/albums/k637/jaiteastu/Hasbro Hero Millennium Falcon/IMG_1349.jpg
John
