Thanks for the video.
Everyone should recognize that Superdave's experience is precisely the experience you are going to get with all of your FBA suits (and the very experience that I have had with the three that I have).
I have told James (Jarvis) at FBA that these suits need to be sold as hobby kits because they are not truly 'finished'. When you get your suit it will be a complete path of mystery solving - there are no/limited instructions for the suits. They are, in fact, a total mystery which will at time be improperly connected. You need to be a sleuth and you need to expect that you will have to try on the suit multiple times before you get it right and configured properly.
Your suit will be incomplete - the video shows that a missile was missing - this is common in these suits and you need to make sure that FBA knows what you are missing. CAUTION: when they send you the replacement parts make sure that they don't charge you COD. I have been burnt by this several times.
Hot glue - they are very very very cheap on their use of hot glue on the suits - and particularly where it is a plastic/fibreglass hybrid, it falls apart quickly. As soon as I get my suits from them I spend the first few days going over all the seams on the inside with my own hot glue. It's a mess, but you gotta do it.
Electronics - be careful with their servos - i have found that if you start pushing them around without the suit being powered up they get out of sync. This shouldn't be the case but it is.
Suiting Up - this is a two person job. If you try it yourself you will damage the suit. Go slow. Don't force anything and if you get frustrated take a break.
Hope this helps.
Murphy1969
