Unbelievably beautiful replica! The hand work really pays off. It just looks "right"
Fantastic job! I am thoroughly impressed with you building everything from the ground up. It is impressive to see you doing the book binding as well as the pages. I am working on my right now, but was happy to start with a blank diary from Indy Magnoli. Very nice work!
Awesome piece!!
Having handled the original hero Diary prop, this is really amazing reproduction
great work
Very good job
Congrats
Stunning, beautiful work, I wish I had the time to try and create one of these.
Thank you, means a lot coming from someone who has done one of the best diaries out there. :thumbsup
What type of paper did you use?
To answer your first question, no, the files won't be available. However, I have considered putting together a file that contains all text, page order, etc. It would be not a printable diary in any way, but it would provide folks with a way to easily understand what all should be in there. Would be offered for free, just something I thought would be helpful to those who want to create their own. I've only thought about it though and haven't started anything, so who know if or when I would have it done.
As for paper, I stay on the thin side and use 24lb. Researching how the original diaries were constructed and seeing a Hero in person, I have some theories on why this is more accurate. I know most folks use heavier paper, which is easier to age, but I prefer the results of what I'm using, even it requires a bit more work.
I think ive got an idea of all of the pages and the inserts now after a bit of research it would have just been a help to clarify. But no worries, but that list would be a help to know where the inserts go as im not quite sure about that yet
What would be you best tip for aging this type of paper?
I brew strong coffee and fill a baking sheet with it. I dip each page into it, so that the entire page is saturated. Like so:
http://i65.tinypic.com/amdsx.jpg
I lay them aside and sprinkle a bit of regular coffee (that's the only thing I've found to watch out for, some coffees clump really bad and stick to the page, I'm using the absolute cheapest, from a store called Sav-A-Lot and it doesn't clump) onto the page. Dip the next page and lay it on top of the other, then sprinkle more coffee onto that page. I do this two signatures at a time, then hang them onto a rack (keeping them in order) I built out of yard stick, a 2x4, and piece of scrap MDF:
http://i66.tinypic.com/f2t4ea.jpg
After they are fully dry, I brush all the dried coffee off the pages. It creates a slightly darker stain wherever it was, but it blends into the other colors well, doesn't look like obvious fake aging. Once they are all brushed off, I fold the signature, and place them into the book press. I place a damp (just barely) paper towel after each 4 signatures. This puts just a bit of moisture into the pages and allows them to relax, so the pressure of the press makes them completely flat, no wrinkling (which I hate). I take them out after a couple of days when they are fully dry again and they're ready to bind. After binding, I put them back in the press and plow the edges. Plowing the edges creates a perfect edge, too perfect in fact. I sand the edges a bit to rough them up and use a diluted oil paint mixture to stain the edges of the book. After I've put on the cover and fly sheets, I use the same diluted oil paint on a rag and apply a bit to edges of each page, so that they pages are a bit darker at their edges. You want to go really light with the paint, using a technique similar to dry brushing, just using a rag instead of a brush.
Wow thanks for that it's a massive help... I was thinking about just printing all of the pages but you have convinced me that it's sacrilege one more question though... what type of pen? I think I'm all set to start making now! Thanks.
