Spider-man (Raimi) 3D Print Files/Pattern - FREE
Spider-Man-1410915.jpgAnother reference for the front spider.
Just downloaded the Raimi layered pattern file. Is there a file with the symbols already on the suit?
Here's some I quickly edited using stuff posted previously in this thread. Remember the front spider is split that way to accommodate for the neck dart being sewn up.
File with flat spider symbols
Preview:
Download link:
https://drive.google.com/file/d/0B2efCJNX3F76VTdtMmdNeC05Mkk/view?usp=sharing
File with beveled spider symbols
Preview:
Download Link:
https://drive.google.com/file/d/0B2efCJNX3F76QU9kNEpPRWVlZDQ/view?usp=sharing
File with different bevel on back spiders
Just the bevel effect is slightly different on the back symbols, not really obvious in the preview.
Preview:
Download Link:
https://drive.google.com/file/d/0B2efCJNX3F76SjNmMzlxTjdRSG8/view?usp=sharing
I'll get the PSD file uploaded in a bit for anyone who wants to edit the symbols or whatnot, file's a hefty size.
Let me know if there's any problem with the files and have fun :)
I hope this isn't to much but I don't really have the photoshop file or skills so I wondering if maybe you could add the 2002 spiders on a pattern file.
I looked at my file its says height 25000 an im 5'11 is that good ?
Thanks!
I sized it for someone around 6'.
If I remember correctly, there is a chart or something in a thread here that tells you if you measure from the middle face to the point on the bottom of the belt it should be ____? I am sure someone here has seen it and can point you in the right direction.
EDIT:Found this for you.
...and this is from here: http://theleagueofheroes.yuku.com/topic/7648/spiderman-suit#.Ux8u7oVF9WI
The way to resize Spiderman patterns is fairly simple once you know where to measure.
There's a point in between where the eyes are (and the costume's mask kind of pulls apart) that's the top of the line you're going to measure. The bottom is just under where the red belt stops.
Here's what I mean.
For a large costume, that length needs to be 29". For a medium 27". For a small 25". A lot of spiderman suit makers will tell you they have custom patterns, but after hanging out for years on the SHH forums, I've been told by more than one source that these three lengths are all they use.
Hope that helps. Oh also, you might want to make sure the saturation on your file gets set to 100% (this may mess with the colors, but you can fix that afterwards)
Does anyone know if there is a way that you could make sure it fits from your computer, because I'm making a suit around 5'11 and I don't want to end up with something too big or too small. Can anyone help?
...and we begin.
Spider Files
http://www.kenlandrum.com/spider-man/frontSpider.ai
http://www.kenlandrum.com/spider-man/backSpider.ai
These are the 3D files extruded to 2mm and slightly beveled.
3mm thick versions
http://www.kenlandrum.com/spider-man/spiders-3mm.obj
http://www.kenlandrum.com/spider-man/spiders-3mm.STL
2mm thick versions
http://www.kenlandrum.com/spider-man/spiders.obj
http://www.kenlandrum.com/spider-man/spiders.STL
Webbing Files
Zipped file for all of the web vectors.
https://drive.google.com/file/d/0B_sNvgA37t6qTC1CSE9hQVZfZzQ/edit?usp=sharing
View attachment 293983View attachment 293984View attachment 293987View attachment 294009View attachment 294029
Extruded/beveled 3D web files:
View attachment 296733View attachment 296944View attachment 296959
STL
https://drive.google.com/file/d/0B_sNvgA37t6qbmUzZHVqVlo2dDA/edit?usp=sharing
OBJ
https://drive.google.com/file/d/0B_sNvgA37t6qSUVvVkxCNzN1Szg/edit?usp=sharing
Pattern Files (Raimi Version)
https://drive.google.com/file/d/0B_sNvgA37t6qQktUN3N4MTZfTjA/edit?usp=sharing
Layered .psd (colors, muscle shading, bricks, webbing all separated)
https://drive.google.com/file/d/0B_sNvgA37t6qNFU3WmZzRWhxZzQ/edit?usp=sharing
Bricks only, non-distorted version.
https://drive.google.com/file/d/0B_sNvgA37t6qR1B1cGpHZkNWbTQ/edit?usp=sharing
https://drive.google.com/file/d/0B_sNvgA37t6qQnhGaU9IUkxfcWs/edit?usp=sharing
NEWEST colors (web guides only, no spiders) "Ready-to-Upload" CMYK jpg
3D Print Ready Face Shell
Sized to 23cm in height - 3mm thickness
https://drive.google.com/file/d/0B_sNvgA37t6qUkdtZVlHb1FiUmM/edit?usp=sharing
3D Face Shell - print ready .obj & .stl formats
3D Print Ready Lens Files
3D Lens Frames - print ready .obj & .stl formats
Sized to 85mm - Snap distance 3.2mm to accommodate 3mm thick face shell above + fabric
View attachment 300603View attachment 300604
STL:
https://drive.google.com/file/d/0B_sNvgA37t6qblZzOUd2QXg1ZTg/edit?usp=sharing
OBJ:
https://drive.google.com/file/d/0B_sNvgA37t6qWjZTSXlHMVhtODQ/edit?usp=sharing
Tnx dude
5'-11" should be just fine.
Im sorry i ask many questions dude but i downloaded the um Google drive file u said it works for people who's 6 an lower so does it work if your skinny an a small torso an long legs when u order it on demand or do u have too change it before u order it on fod?
6 foot + or- an inch.
it will fit, but on the crotch it will be lower and not tight fitting.. a bit like hip hop style ;).. it looks not very good. i have also made a own pattern, with longer legs ;)
The issue you're describing is something thats done via sewing your seamstress will need to sew to your measurements. If you're looking for a suit i print fod and sew sub dye, I'm known around here a bit.
