EXECUTOR
Wow, you are working at a whole new level of creative insanity...and its fabulous! - this is going to be a display piece to die for when you are finished :)
Can I ask about the nibbler you are using? I've tried in the past to find something like this with a view to cutting the notches for the Falcon plating, but not really found anything that looked suitable. Can I ask where you got yours and what description I should search under?
Cheers
Nick
I think i just pee'd my pants a little, absolutely jaw dropping.
Fantastic sir.
Will you be lighting this.
Gag
That tool is called a "nibbler" here in the US. I'm pretty sure it's what they used on the ILM models at that time too.
Hi
I knew this sort of tool had been used by ILM, but haven't actually needed one so far. Seeing what you had achieved with the Executor, I figured whatever you had found would be perfect for my future Falcon plating work. Plus, you often find with a tool that once you have one, you end up using it more than you thought anyway.
Cheers
Nick
Thanks Gort ! ;)
You didn't know this tool ?
what tool you used it ?
