This is a 2 part mold
I think I'm crazy but I figured I'd ask:
I'm not as used to comparing so odds are I'm wrong.
What you are seeing there are the two masks not being at the exact same angle. The one on the left, the test pull is rotated much more to the left, while the one on the right, is rotated more to the right, exposing more of that temple area.
If you look at other areas, you will see the same thing. Take a look at the upper left edge of the jaw. On the test pull you can see it, again, because the test pull is rotated more to the left, exposing more of the left side and less of the right, whereas on the screen used piece you don't see that part of the jaw at all because the mask is rotated more to the right, hiding the left side of the jaw entirely.
Also keep in mind that these masks are made from a semi-flexible material (the originals have hardened over time) so that can play into minor distortions in shape, but I think the thing you are pointing out is almost entirely due to the differences in the angles of the masks.
Did you ever hear back on if this is the original or a direct cast off it? I went back to check and make sure I didn't miss the announcement and it doesnt look like I did.
Art, I'm so glad you ended up with this thing.
Lighting and angles are everything
Thanks! I am beyond thrilled myself. I have wanted a really good Frank mask for a long long time now and this is one of those things that is so organic and so asymmetrical that it would be almost impossible to replicate, so to get this mold is more than I could ever hope for!! >>>clip<<<
Mind you he woke up the next morning and told me he saw it on ebay the night before and was worried it wouldn't still be there. I'm like, go buy it...NOW! >>>clip<<<e!
