if you have any padding in the helmet I would take it out or make it as thin as possible because it looks like the helmet is sitting to high.
Suit looks good but if you have any padding in the helmet I would take it out or make it as thin as possible because it looks like the helmet is sitting to high. The X part should be around your eyes and the bottom of the visor should be at or below the tip of your nose.
Other than that it looks good.
I placed the foam between the negative and the positive templates, heated it with a heat gun and then squashed the two templates together. I don't know if I'm explaining myself properly, if not, I will post a drawing or something
