Hi Gang,
Weekend Update Part I! Enjoy!
Lots of work continues on the cockpit entrance coils. Lots of sanding, filling, sanding, etc
The single coil that connects to the red PVC pipe get a new base
I cut new fins for the extra coil and only 1 didn't fit?
Putting all the puzzle pieces together
Filler
1st round of sanding and added the pipe connector
More filler
Lots of sanding and filling
Worked on the sister coils
Primer!
This was a grueling process...
Normally I would have cut this piece with 1/4" acrylic but I had to stack 2 pieces of 1/8th to allow enough clearance for the braided hose which peaked just above the ring - so one layer matched the ring, the top layer is the actual sectioned cover/id
More filler... UGH
What a mess
More filler and sanding
Then added visual interest to the coil covers
Primer!
Slowly getting there...
1st round of color
I laser cut a new backing plate for fan greeblie
Acrylic PVC pipe connector
Tinkering with this idea
This is where the fun begins... Huntsville Scott had an old "Daytona USA" coin op game and said I could have the wiring harness out of the cabinet... we spent a few hours breaking down the cabinet and then separating the harness
We then used the old harnesses to begin a basic layout of what might work where on the cockpit entrance...
Might to need to break that harness down a little more
Trying out different configurations (nothing is final yet)
Whew... this is going to be fun!
Finally... I cut two lower panels. Since the coils will have LEDs I needed to make access easy
Part II Coming!
