Hi Gang,
A Super Quick Morning Update!
I laser cut new "connectors" for the MK4 box
A new guide plate
The connectors will simply fit in place
Adding some color
Then Silver
So, remember that awesome greeblie I found? I was able to pick up a Rolls Royce Engine Flame Tube! Also known as Quad Laser Barrels, IG-88s Head, the Cantina Drink Dispenser, etc etc etc :)
Sorry for the lack of updates. I've been working a few other projects but I'll get back to it tonight! :)
Stay Tuned
Hey Sofa, :D
No problems on lack of updates! Although we joke about it (and do genuinely look forward to our greeblies fix) we do realise you have a real life and other projects separate from the "pit". :thumbsup
Nice find on the Flame tube, a true Star Wars multi use Greeblie, LOL!!
Roughneckone:cool
Hi Gang,
Blast From the Past! Hard to believe it was 2 years ago today that we added sound and lights to the center console...
More to Follow
It's crazy that it's already two years ago... was that still the original console?
What are you going to use the Rolls-Royce for? Part reference for the quad? Or is IG-88 getting added to the to-do list?
Hey Sofa, :D
Roughneckone:cool
Hey R,
Real life is getting in the way! ;) The Flame Tube was one of the lucky finds. We're all excited!
Hey Y,
Time certainly does fly! I can't believe it's been that long. Finding the Flame Tube, as I mentioned, was lucky and it made sense to get it than let it go to someone else. Since we're going for total screen accuracy, having one on hand will help us when we actually recreate the full scale on screen quad as opposed to my recreating a sort of hybrid. Sorry, no IG-88s in the near future. ;)
Hi J,
Thanks for the support! It certainly has evolved from those early days. :)
Oh yeah. Seeing how this superb Falcon interior evolved over time is really great. Cannot wait to see it finished, this will be as cool as the screen used one, especially knowing your true dedication in making it :thumbsup
I can get you more of those if you need them.
Hi Gang,
Early Morning Update!
Spent a lot of the weekend designing new back wall greeblies. I had to change the size of one main greeblie for travel and access panel purposes but it will still look the part! And as always... there was more spent at the laser cutter than the was with the actual build.
This is the new "scaled down" back wall greeblie
Lots of routing and filling to do!
Round center pieces being adhered together
Made a few modifications and was able to fit this board
The housing, from what I can tell, is painted silver and the board is painted black
A brand new greeblie! More on this guy later
Another new back wall greeblie. This will have 3 switches installed and painted the standard black
I would up having to recut the back plate - I forgot to remove the back for access (UGH)
Adhering the body together
Filler
Top plate minus switches
Designed a new housing
Along with a new side greeblie
And if you look closely there is a small thin trim piece along the top of the housing
I'm really hoping this guy turns out!
I then changed the simple round pattern of bolts to actual looking bolts
I'm hoping to have all these different edges from various greeblies sanded smooth so I can bring out the router!
I then took a DUSTY paint brush and added some simple weathering to many of the black greeblies
Note the dusty / worn looking edges
I finally added paint to these two greeblies
This guy will be painted silver
More to Follow! And eventually I'll mount all these things to the back wall panels! ;)
Sends Shivers down my spine Every time!!! Amazing flawless detail on everything Sofa and the IG-88 HEAD :D!!! One of favorite bounty hunters other than Fett, keep up the great work!
I hope I'm not a debbie downer, but the flame tube is not the exact one used for IG-88, cantina, etc. It's pretty darn close, but not exact. The multiple seams and holes at the bottom should only be one seam, with a larger hole beneath it.
Scott
Hi Gang,
Another early morning update!
Got this guy all finished up when after looking at a behind the scene image the housing IS in fact silver
Painted silver
All I need to do is mount the boards and then to the wall!
This guy is almost finished
The MK4 Panel is coming along
Have to add more filler to the little knob
Closer to being finished with this one
The housing gets a first coat of filler then sanding
Then primer
More filler
I'm really enjoying this new greeblie!
Other pieces getting filler
Painted this base silver
I dont really like how this guy turned out...
If all goes well, I'll break out the router this afternoon! Stay Tuned!
