Snatcher - Metal Gear MkII Robot Build
Nick,
Try some of this stuff for your pink insulation. It makes the stuff bullet proof. It also has a tooth so bondo stick to it AND it seals it so you can use a solvent based paint or poly on it.
And it's cheap and goes a long way and is water based.
Hot Wire Foam Factory
Used it on some pink foam feet and it's held up as good as fiberglass.
Laffo.
Holy cow. I might just have to get a bucket.
Nick,
Laffo.
Interesting stuff. Could it act as a replacement for body filler? It says in it's description that it's sandable.
Bondo and it's ilk is stinky enough that I'd love to find a water-based alternative.
Nick
Coated the head and two body pieces in a gloppy layer of Evercoat Metal Glaze. This stuff was recommended in SteveNeil's awesome enterprise build as a vastly superior product to regular Bondo. Bondo gets incredibly hard compared to other body fillers and the hardness isn't important in our modeling needs.
Started sanding the bottom body piece with my Ryobi Mouse sander with an 80 grit pad. It grinds down the material at a nicely controlable rate that I like so far. Looks like I'll have to route out the center groove with a dremel and a pipe with sandpaper wrapped around.
Nick
nice!
i'll see if i can import some of that stuff, looks really usefull.
Been meaning to make a replica of the pistol myself, added it to the 'to do' list for this year
:lol This just keeps getting better! I was asked not too long ago by a friend whether Gibson's head was a possibility in the future.
First round of sanding the body filler went pretty smooth last night.
There's a few low spots that I still need to build up a bit more in several areas but I'm happy with the first round of filler shaping.
Nick
More sanding and the first layer of filler primer.
Still trying to figure out the how to approach the forms in certain undefined areas. Since this guy only lived as low res 2D graphics, it's gonna be tricky to make those spots look good. Weird shapes abound.
There are a few thin spots in the skin from all the sanding but I don't think that'll make much a difference once more filler, and primer keep get added on and sanded down.
We'll see.
Nick
Put in a couple more hours of sanding, primer, more body filler to raise up a couple low spots. I even started applying some red glazing putty to some of the bigger pinholes and gashes.
I hope these micro updates aren't annoying. I always want to see more steps in every build up so I thought I'd make that happen here and avoid the giant leaps in levels of finish you see in some build logs. Baby steps.
It's getting there.
Nick
Sorry Nick,
No, it won't work as filler because it's watery, but great as a tooth coat and great for hardening and protecting the foam. Gives a great base to start putting on whatever filler you decide to use. You can throw the piece across the room after you coat it.
Laffo.
Been juggling a few projects so progress has been slow.
As I've been shaping this bot down the form is really taking shape. I followed a bit of Volpin methodology that he used on one of his Daft Punk helmets and made a strip of sandpaper backed with duct tape and used that to smooth out all the high spots. The strap rides along the curved surface wonderfully and tears down those high spots perfectly. Highly recommended technique.
The alternating layers of primer really start to describe the topology of the form's surface as you are sanding it down.
The only issue now is that the skin is getting really thin and even is cutting through in a couple spots.
Here are a couple areas of foam that I think melted when I put on a layer of primer.
I still need to do a bit more sanding in a couple areas and also need to carve in panel lines which would probably go into the foam layer. What to do?
I was afraid this might happen. Should've globbed on the body filler a little thicker initially. Oh well, live and learn.
Here's where I'm at right now-
It's really, really close though.
Nick
Nice progress, it's starting to look really smooth. I don't know how deep you plan on going with the lines, but that problem might be solved by laying down tape strips for the lines and then spraying a lot of high build primer. When you remove the tape you have a nice line, and haven't gouged the prop.
I thought about doing that. It might be the solution I'm looking for.
Once I realized that I was getting super close to the foam I actually laid down about 5 good coats of high build primer to help build back a bit of a barrier.
Hope the tape method gives me a good look. Might even be easier to get the curves I need to achieve.
Nick
