upgraded hoverboard! done!
Razor, that looks really great! This has nothing to do with Roland's upcoming kit, right? This is a sticker you did?
Looks awesome, Razorsharp192. I might recommend a mod though... for the foot strap, in order to make it more sturdy and poseable you could embed some thin copper wire in between your pink fur and white material.
That way if you want to you could pose it up or down repeatedly, like so.
I've done this to my foot strap and it works like a charm.
anyone posting pics of upgraded boards ...please watermark or alter the photo to show its modified so mattel cant take credit for your hard work
Do you use seatbelt webbing?
Looks a little on the thin side... I think the originals sported 2" wide (50mm) seatbelt webbing for the backing.
If you do use the seatbelt webbing someday you'll need to put wire in between there if you want it poseable.
Again, beautiful work there. I want to upgrade mine now!
I started with Roland's excellent graphic, then tweaked it here and there and adjusted to fit the Matty hoverboard, but no, it has nothing to do with Roland's "kit", I had this printed myself.
No the webbing I used is a more rigid than the seatbelt material so stays in place nicely. I agree the width is slightly thin, but this is due to the width of the slots in the footpad and I didn't want to have a thin bit (to fit in the slot) then make it wider, I don't think that would look very good (I think it would look a bit home-made).
