Pyro X-Wing kit WIP
VERY cool. Nice to see that someone has finally added motors the way they more or less did it originally.
Thanks everyone!
The motors I use are 12mm geard motor.I want to use this size because the
inside of the lower fuselage is very small space.If you use a vac-formed fuselage,you'll get no problem to use lager size of motors like studio model,but as for a resin casting fuselage,I think you'll need small diameter motors.
It took a lot of time to add the moving wings device.I can image how hard it was to design the armature and accomplish it.I really thank Jason for this and reasonable price.:)
Thanks for the replies everyone.I'm honored.
If you do once,you'll find that it will not that difficult.Now I feel anything is possible.
Next step is controling the motor.Let's do it!
Hello,
Does anyone know where I can get these?
By the way,I just found this decal in the airfix messer's box and took a picuture of it next to Jason's decal.Almost the same though.
I believe those are the female brass electrical contacts. You could make them out of some brass tubing by rounding the end. I'm sorry I do not know where to source an original part in this case. Maybe someone else does.
