This is for the right side . Lift brackets go on the inside and as shown, invert for left side
Upper shown left side here,
From outer side:
Screw lift bracket , plastic washer, sight bracket , lock nut
Invert for right side
Replace exactly as you have the original top plate with the new top plate and secure to side plates and whale plates
Make it as round as possible
Carefully 1 mm at at time shave the alloy top plate to get an almost perfect fit to your pod.
On mine I left a lip but this should not matter if you
In your case do not cut these yet
