now for the door card ..it was crudley molded as one piece into the inner door frame , this made making the doors close hassle , so i cut away the door frame and door card/trim
heres the orig piece
cut into two peices
frame glued to the door
lots of filler and smoothing to make it all fit together again
new improved door, with seperate panel ready in primer
the inner door trims werent so good so ive modded those to make them a little better
here you can see the inner grab handle , its too far toward the rear of the door
i cut it away with my dremel and moved it along and glued it into place
filled , rescribed the outer line and primer, just some more detail work before paint
the upper part of the arm rest was smooth with
zero detail , the actual car has switches and a vent here , i scribed some detail in best i could
