I haven't got this far on the blog, but I have some things I want to show you guys.
I refined the armature.
They are in essence the same as before, except I allotted for some of the detail parts. I added a rail for the top of the nacelle jig, so the parts will keep a consistent spacing.
I changed the length of the base rails. Why have extra length you don't need.
Here is something else I did(and replaced).
Please note the greenish/tan bussard disks with the LEDs.
I junked them, your supposed to mount the supplied motors to them. These were not done very well, vibration could reek havoc on the electronics, and I had one bolt sit on the lip of an LED(I wish I had a pic of that). That's not very good for it shows poor planning, and to fix the issue could cause even more problems.
The Tamiya motors will be much better in something else. But some of the parts supplied are useful. I found the motors were not stable enough for the application. The supplied spinners(domes) were to big, no matter what I did they would rub on the outerdome. The instructions didn't say a thing about how to stabilize the shafts. There is another issue on top of this that compounds the spinner problems. That is the bussard housing/mount, since the part is cast it can deform during the casting run. Depending on a variety of factors. The existing parts supplied with the kit required more precision than the kit can deliver. Then there is the noise, something sure had to be done.
So I decided to go a different route, I changed it all.
Here is the changed bussard with a replacement spinner. The spinner is one half of an acrylic ball you can get at most craft stores. It's smaller than the supplied spinner, but not by much. But it will give enough space to safely run the spinner without damaging the outer dome(just remove the lip of the acrylic dome).
Here is my first try at the making the spinners. I used 1/8" pin striping, and I frosted the dome afterwards, the effect worked very well. But I wasn't happy with them, I drilled the center hole by eye(that can be real hit and miss). That didn't go so well.
In the pic is one of the new spinners, I used my router to drill a 1/16" hole in the center. Here is the jig with a spinner.
If you notice there is two holes in the center. The other hole is to accommodate an offset pin used in the opposite spinning spinner. When I put it on things were moving much more smoothly.
In the jumble of wires is the 12 volt gearmotor. It spins at a max of 50 rpm, since the manual says it supposed to run at 30 rpm, I figure I'll be fine. I can use a resistor or a pot to control the motor speed. Which is what I wanted to do.
Why all of the wires?
For all of the leds, I even put in the running light on top of the bussard.
This pic shows how I mounted the motor, I used some of the parts supplied with the model to mount the spinner. I figured why make all new parts, When the ones supplied with the model were fine. I selected the motor on the basis of it's shaft size, which is the same shaft size as the supplied motor. I made a plate for leds, and a center hole to allow the spinner shaft to pass. Why all of this effort to replace this mechanism, I'll show that in the future.
Any questions/comments?
