Back at Last !!!
Hey there all. I know it has been a while since I last posted, but that doesn't mean I have stopped building or dropped off the grid. Been working out the engines, electronics and paints, while dealing with the day to day stuff. Sorry if this is a long post however as always, I like to pass on what I have done and experimented with.
First of all, my air compressor died so I had to get a new one. It is a beauty !!!! The old one is on the left of the first pic below. Cost me all of $140 Oz online...Most happy.
Moving on, the main thing I have been working on is getting the engines detailed, painted and working. This can't be done without working on the back plate and also the bottom plate of the ship. So here comes my diatribe.
Engines: I think that in my last post I had detailed the main engines and given them an undercoat. Once this was done, I focused on the inside of the main engine nozzles. There are 16 ribs inside each nozzle and inside those, a short tube. A mate of mine sent me the copper tubing which then needed to be cut to size and then polished to remove any burrs. These are shown in the next 3 pics.
I was trying to decide if I should enamels or acrylics for the main colours of the ship, including the engines and decided on enamels because I had a larger variety of greys and whites in enamel. First was the base coat I made up which I have called "Sidious Grey". It is a It is a 25 / 25 / 50 mix of Revell matt 77 + 74 and Tamiya X-20 thinner. It looked ghastly when first sprayed on but then after applying a 50 / 50 mix of Revell matt 76 and thinner, things looked somewhat better (next picture).
Next while working out how to create highlights and grimy detailing by accident, I found that by rubbing my finger over the engines produced quite a nice used look although it was glossy (next slide please).
To finsh of the grimy look, I applied some Tamiya weathering master soot. to seal it all and give a matt look I used something which most people seem to hate - Humbrol Mattcote. This is the first time I have used this product but after strirring throughly in the bottle first then, thinning with 75% of X-20, I was well chuffed with the result. The greys tended to blend together and I had no problem with any yellowing, bubbling, etc (another picture, large engines with Dullcote).
I am nearly done. The main engines were then attached to the back plate and wired up.
The bottom plate: To get the colours working in harmony, I also sprayed the bottom of the ship with Sidious Grey after which I did some masking. After that was the #76 mix which was on purpose sprayed in an uneven way. This ship is going to represent one of the first out of the shipyards that lasted through to the start of of the Empire.
That's all for now folks. Time to some more masking.
Happy building.
