Y-Wing 1/48 resin model [WIP]
moonbus
SB, is there a way to inject some type of light blocking material at the leak point? Like white printable latex calk? It seems like it could be overcome somehow. Looks great otherwise.
Take care, Tim
StevenBills
In theory, yes, you could putty the gap or something similar. But the way that Bandai have engineered this kit is that they made the cake section removable to access the switch for the lighting, which I just went along with. I have an IR remote powering the engines, but the main LED strip is still accessed by removing the cake section. I'm still trying to think of a workaround there.
SB
moonbus
Well if it comes off can you glue a second piece of styrene inside the "cake" section that would block the lights?
. l-------cake wall
. l
ll
ll
l---styrene
______________________________________-----------top of main body
Or place a sheet of polyethylene (cut open Zip lock bag) on the main body and then put some putty on the underside of the cake and place it on the polyethylene sheet, squeeze, and let dry. the putty will not stick to the sheet and should fill the gap exactly once the sheet it removed. It just will be a simple mater of shaping the outside of the cake and touch up paint.
Or just enjoy the ship as it is, a gorgeous piece of work.
Take care, Tim
Jedi Dade
leakage around the superstructure seems to be a common issue with this kit. I've seen some blame the internal structure that holds the lights for not letting tings seat properly... maybe some judicious cutting is in order if its not already glued in...
Jedi Dade
rooker2k
Member
StevenBills "Yours is looking great though! Have you had any trouble with parts fitting together at all?"
Answer .. no i dont had any problems .. everything fit perfect.
the second prototype is ready now .. will show you some pictures later .. the main body is full printed in one piece.
related to your ISD the light leakage this can be fix much easier .. i use a remote controll to reduce the light intensity this was fixing my problem.
Jimw100
I’ve finished printing out all of the bits for my Y-wing now. I wish I had made a bit more room in the body for electronics as it’s going to be a squeeze. Plus getting the fibre optics done in the cockpit will be difficult since I went back and printed the top and bottom sections in one piece.
I also built new main guns out of aluminum and brass tube so I can light them up, but fitting the LEDs and wires in there may be a bit of a challenge.
But overall looking good, can’t wait to start putting it together
StevenBills
Here's an image I made with my SD:
Now it's time to get back to the Y-Wing!
SB
Jimw100
Got the lighting for the cockpit and guns done. The picture is not great - difficult to get good photos of the lights. This was actually much easier to do than I expected. Usually I get carried away and try to put 10 different leds in, but I kept it simple with 5 for the cockpit and one for the guns. I actually forgot to light one of the fibre optics, but the light leak is bad enough that it does show up anyway. Win for shoddy workmanship!
Jimw100
I've started gathering materials for the various pipes that run along the chassis. I've ordered a few different diameters of brass tube (1mm, 1/16" and 1.5mm) which I think should be in scale. Does anyone have any tips (or tools) for making precise and sharp bends in these? In the past when I was making my hasbro Falcon I used a couple pairs of small pliers but I could never get the bends as "sharp" as I wanted.
edge10
If you have your heart set on using metal tubing, you might need to invest in a special tool, or two. Here is a video showing how to do it:
Jimw100
Ah great, thanks! Sorry, I meant to say metal rod instead of tube, which I think makes things easier. I didn't so much have my heart set on using metal as I thought it would be easiest. If I can find a hand bender like that which will cope with smaller diameters that would be perfect. I'll have a look
Jimw100
I printed off the whole main piece of the chassis in one go, as a lot of the small greeblie-covered panels were getting distorted during the printing or curing process, so they weren’t fitting well. And I wanted to make a few more mm space inside for the electronics.
The print turned out pretty good, I was expecting it to be problematic due to all the supports all over it but the only problem was that the bottom of it had been incorporated into the skate that the supports come out of. I’ll need to do some filling and sanding to sort that out, but should work out okay.
0F70BD22-2D3F-4692-86FA-B1125379582B.jpeg 5FECB7FB-C451-4FB2-A006-421ADE0D5CCB.jpeg 9A98AC92-AAF5-456C-8CCB-C50E14450DB3.jpeg
StevenBills
View attachment 1329650 View attachment 1329651 View attachment 1329652
Wow, that's brave! And you can fix most things on resin with a bit of elbow grease and sandpaper.
SB
