BobSmith42
New to the forum and wanted to share my current project I am working on:
While on the look out for new things to make a few months ago, I was playing the CCG Hearthstone. One weapon card available is a weapon called Gorehowl, a rather large orc axe and the card image and text got me curious (this is the second WOW prop I have made). I started looking for reference images and had gathered a few before I found this version by Kamui Cosplay.This and reading Bill Doran’s new Foamsmith book was pretty much my inspiration for making it from foam, plus I have only made one foam prop before. It also used worbla which I hadn’t used before and wanted to give it a go. A blueprint was then made using some of the reference images and then scaled and printed.
I plan on adding and changing something to make it my own such as more swirls cut into the axe head and angular spikes rather than horns/teeth. The paint scheme will also be different.
Axe head made by gluing several floor mats together, then roughly cut out on a bandsaw and tidied on a scroll saw.
Beveled sections made using a disc sander
The bevels on the axe head were done on a belt sander or with a sharpened utility knife. Must admit I made a mess of the ones done with a knife and had to do some filling.
The body of the axe is pretty much done and just needs a bit more filling and then a heat seal. I'll then cut some spirals into the head before adding worbla details. With the horns on the skull it will be around 1m 30 or about 51 inches
