cerillo
Hello All,
I have a Wookie Kit that I bought from Duck over a year ago and although I'm happy with the outcome I just can't seem to get around making the jaw work. (see diagram below)
I've tried to use the dense foam method as explained above, but the pressure point to move the jaw is at the very bottom, and since the jaw is hinged and will only swing at an angle of 90 degrees. Using dense foam simply will not work . Any Ideas???
