Noeland
This is going to be in our fan film, should we ever continue shooting.
The idea is, I wanted to make something more of a "presentation" pulse rifle that would be issued to guards in the Weyland-Yutani tower complex, but somehting that could be yanked out of the gun case and put into action.
What's it's ending up to be is something I want to display more than I want to let an actor drop on the ground.
I've been working on this thing little bits at a time for a long time now.
Progress pics.
This started life as a WILCO kit, that I started to modify right away.
I knew I wanted something of a "hero" grenade launcher that I could rack, so, I picked up a cheapo springer from ebay.
After mods.
And I modified the plastic spas cage with my own vents.
It was kind of a pain, and I'm not 100% happy with the end result, so I will probably try again.
In the mean time I've set my sights on some other modifications I was thinking on. To start with, I knew I wanted to do something different with the grips.
I knew I wanted to do something with the WY logo that I dig so much, so I did this.
And I was also thinking of dropping in some sort of grip coin.
But ultimately decided on keeping it simple. Now intially I was going to paint the WY logo in white and yellow on a black grip. Then I thought "what if I do something more subtle? I could "engrave" the logo then use a nice deep black and hit it with acrylic clearcoat.
So I fired up the dremel.
And I was very happy with the end result.
So, the next step was to start putting it together and painting it. I knew I wanted a flat black/glossy black color scheme with accents of silver. The shotgun chamber, and some other odds and ends on the Pulse Rifle would be silver.
Now, for the grenade launcher I didn't have the benefit of using a real shotgun, and the airsofts don't really work the same, so I needed a crossbar type arm to charge the GL. I ended up using something I found at home depot, and it worked perfectly.
So, here is where the Pulse Rifle stands today:
I still have an aweful lot of work to do on this, and I've pretty much decided I have too many hours into it, and it's too fragile to have on set.
So, it's just going to live in a nice display case.
Thanks for looking.
Noeland---------------------------------
Progress pics.
After mods.
Thanks for looking.
